[SOLVED] Run calculix from python API using a previously written .inp file
EkaitzEsteban
Postby EkaitzEsteban » Mon Sep 24, 2018 4:20 pm
I create a simple box in freecad. The .inp of this file is the following one:
DEFAULT .INP file
** written by FreeCAD inp file writer for CalculiX,Abaqus meshes
** highest dimension mesh elements only.
** Nodes
*Node, NSET=Nall
1, 0, 0, 10
2, 0, 0, 0
3, 0, 30, 10
4, 0, 30, 0
5, 20, 0, 10
6, 20, 0, 0
7, 20, 30, 10
8, 20, 30, 0
9, 0, 0, 5
10, 0, 15, 10
11, 0, 30, 5
12, 0, 15, 0
13, 20, 0, 5
14, 20, 15, 10
15, 20, 30, 5
16, 20, 15, 0
17, 10, 0, 0
18, 10, 0, 10
19, 10, 30, 0
20, 10, 30, 10
21, 0, 15, 5
22, 0, 7.5, 2.5
23, 0, 7.5, 7.5
24, 0, 22.5, 7.5
25, 0, 22.5, 2.5
26, 20, 15, 5
27, 20, 7.5, 2.5
28, 20, 7.5, 7.5
29, 20, 22.5, 7.5
30, 20, 22.5, 2.5
31, 10, 0, 5
32, 5, 0, 2.5
33, 5, 0, 7.5
34, 15, 0, 7.5
35, 15, 0, 2.5
36, 10, 30, 5
37, 5, 30, 7.5
38, 5, 30, 2.5
39, 15, 30, 7.5
40, 15, 30, 2.5
41, 10, 15, 0
42, 5, 22.5, 0
43, 5, 7.5, 0
44, 15, 7.5, 0
45, 15, 22.5, 0
46, 10, 15, 10
47, 5, 22.5, 10
48, 5, 7.5, 10
49, 15, 7.5, 10
50, 15, 22.5, 10
51, 10, 7.5, 7.5
52, 10, 7.5, 2.5
53, 10, 22.5, 7.5
54, 10, 22.5, 2.5
55, 5, 15, 7.5
56, 5, 15, 2.5
57, 10, 15, 5
58, 5, 7.5, 5
59, 15, 15, 2.5
60, 15, 15, 7.5
61, 15, 7.5, 5
62, 5, 22.5, 5
63, 15, 22.5, 5
** Volume elements
*Element, TYPE=C3D10, ELSET=Evolumes
37, 46, 5, 1, 31, 49, 18, 48, 51, 34, 33
38, 6, 41, 2, 31, 44, 43, 17, 35, 52, 32
39, 46, 3, 7, 36, 47, 20, 50, 53, 37, 39
40, 41, 8, 4, 36, 45, 19, 42, 54, 40, 38
41, 41, 46, 21, 31, 57, 55, 56, 52, 51, 58
42, 26, 46, 41, 31, 60, 57, 59, 61, 51, 52
43, 41, 21, 46, 36, 56, 55, 57, 54, 62, 53
44, 26, 41, 46, 36, 59, 57, 60, 63, 54, 53
45, 46, 1, 21, 31, 48, 23, 55, 51, 33, 58
46, 6, 26, 41, 31, 27, 59, 44, 35, 61, 52
47, 41, 4, 21, 36, 42, 25, 56, 54, 38, 62
48, 26, 8, 41, 36, 30, 45, 59, 63, 40, 54
49, 26, 5, 46, 31, 28, 49, 60, 61, 34, 51
50, 41, 21, 2, 31, 56, 22, 43, 52, 58, 32
51, 26, 46, 7, 36, 60, 50, 29, 63, 53, 39
52, 46, 21, 3, 36, 55, 24, 47, 53, 62, 37
53, 3, 21, 4, 36, 24, 25, 11, 37, 62, 38
54, 6, 5, 26, 31, 13, 28, 27, 35, 34, 61
55, 1, 2, 21, 31, 9, 22, 23, 33, 32, 58
56, 26, 7, 8, 36, 29, 15, 30, 63, 39, 40
57, 3, 1, 21, 46, 10, 23, 24, 47, 48, 55
58, 46, 7, 5, 26, 50, 14, 49, 60, 29, 28
59, 26, 41, 8, 6, 59, 45, 30, 27, 44, 16
60, 21, 2, 4, 41, 22, 12, 25, 56, 43, 42
** Define element set Eall
*ELSET, ELSET=Eall
Evolumes
** Element sets for materials and FEM element type (solid, shell, beam, fluid)
** written by write_element_sets_material_and_femelement_type function
*ELSET,ELSET=SolidMaterialSolid
Evolumes
** Node sets for fixed constraint
** written by write_node_sets_constraints_fixed function
** FemConstraintFixed
*NSET,NSET=FemConstraintFixed
1,
2,
5,
6,
9,
13,
17,
18,
31,
32,
33,
34,
35,
** Materials
** written by write_materials function
** Young's modulus unit is MPa = N/mm2
** Density's unit is t/mm^3
** FreeCAD material name: CalculiX-Steel
** Steel
*MATERIAL, NAME=SolidMaterial
*ELASTIC
210000, 0.300
*DENSITY
7.900e-09
** Sections
** written by write_femelementsets function
*SOLID SECTION, ELSET=SolidMaterialSolid, MATERIAL=SolidMaterial
** At least one step is needed to run an CalculiX analysis of FreeCAD
** written by write_step_begin function
*STEP
*FREQUENCY
3,0.0,100000.0
** Fixed Constraints
** written by write_constraints_fixed function
*BOUNDARY
FemConstraintFixed,1
FemConstraintFixed,2
FemConstraintFixed,3
** Outputs --> frd file
** written by write_outputs_types function
*NODE FILE
U
*EL FILE
S, E
** outputs --> dat file
*NODE PRINT , NSET=Nall
U
*EL PRINT , ELSET=Eall
S
** written by write_step_end function
*END STEP
** CalculiX Input file
** written by write_footer function
**   written by    --> FreeCAD 0.17.13528 (Git)
**   written on    --> Sun Sep 23 12:50:46 2018
**   file name     --> SimpleBox.FCStd
**   analysis name --> Analysis
**   Units
**   Geometry (mesh data)        --> mm
**   Materials (Young's modulus) --> N/mm2 = MPa
**   Loads (nodal loads)         --> N
I modify the .inp file in order to obtain exactly the same results:
MY .INP file
** Nodes
*Node, NSET=Nall
1, 0, 0, 10
2, 0, 0, 0
3, 0, 30, 10
4, 0, 30, 0
5, 20, 0, 10
6, 20, 0, 0
7, 20, 30, 10
8, 20, 30, 0
9, 0, 0, 5
10, 0, 15, 10
11, 0, 30, 5
12, 0, 15, 0
13, 20, 0, 5
14, 20, 15, 10
15, 20, 30, 5
16, 20, 15, 0
17, 10, 0, 0
18, 10, 0, 10
19, 10, 30, 0
20, 10, 30, 10
21, 0, 15, 5
22, 0, 7.5, 2.5
23, 0, 7.5, 7.5
24, 0, 22.5, 7.5
25, 0, 22.5, 2.5
26, 20, 15, 5
27, 20, 7.5, 2.5
28, 20, 7.5, 7.5
29, 20, 22.5, 7.5
30, 20, 22.5, 2.5
31, 10, 0, 5
32, 5, 0, 2.5
33, 5, 0, 7.5
34, 15, 0, 7.5
35, 15, 0, 2.5
36, 10, 30, 5
37, 5, 30, 7.5
38, 5, 30, 2.5
39, 15, 30, 7.5
40, 15, 30, 2.5
41, 10, 15, 0
42, 5, 22.5, 0
43, 5, 7.5, 0
44, 15, 7.5, 0
45, 15, 22.5, 0
46, 10, 15, 10
47, 5, 22.5, 10
48, 5, 7.5, 10
49, 15, 7.5, 10
50, 15, 22.5, 10
51, 10, 7.5, 7.5
52, 10, 7.5, 2.5
53, 10, 22.5, 7.5
54, 10, 22.5, 2.5
55, 5, 15, 7.5
56, 5, 15, 2.5
57, 10, 15, 5
58, 5, 7.5, 5
59, 15, 15, 2.5
60, 15, 15, 7.5
61, 15, 7.5, 5
62, 5, 22.5, 5
63, 15, 22.5, 5
** Volume elements
*ELSET, ELSET=Eall
Evolumes
37,
39,
40,
41,
42,
43,
44,
45,
47,
48,
49,
50,
51,
52,
53,
55,
56,
57,
58,
60,
*ELSET,ELSET=MaterialSelectedNodes
38,
46,
54,
59,
1,
2,
5,
6,
9,
13,
17,
18,
31,
32,
33,
34,
35,
** Materials
** Steel
*ELASTIC
210000, 0.300
*DENSITY
7.900e-09
*MATERIAL, NAME=SolidMaterialSelectedNodes
*ELASTIC
210000, 0.300
*DENSITY
7.900e-09
** Sections
*SOLID SECTION, ELSET=MaterialSelectedNodes, MATERIAL=SolidMaterialSelectedNodes
*STEP
*FREQUENCY
3,0.0,100000.0
*BOUNDARY
*NODE FILE
U
*EL FILE
S, E
U
S
*END STEP
**   Units
A manual procedure exists; which consists on copy and paste my,inp content in edit.inp file option, save it and then press run calculix button. However, this is not a solution because I want to run in a loop a large amount of simulations automatically.
The main problem is how to execute calculix from FreeCAD python API in order to read my.inp file and simulate.
I attached my file: SimpleBox.FCStd
BTW: This post is related with the following three questions:
https://forum.freecadweb.org/viewtopic.php?f=18&t=31100
https://forum.freecadweb.org/viewtopic.php?f=18&t=31123
https://forum.freecadweb.org/viewtopic.php?f=22&t=23467 - here I post here too but I dont if it is the correct place, because it is related with FEM and run calculix solver....
Thank you in advance,
Ekaitz.
EDIT: Solved here:
https://forum.freecadweb.org/viewtopic. ... 10#p258417
Thank you bernd.
SimpleBox.FCStd
(9.31 KiB) Downloaded 21 times
bernd
Re: [Help] Run calculix from python API using a previously written .inp file
Postby bernd » Tue Sep 25, 2018 8:06 am
- open FEM example from StartWB
- run analysis in Python
# run the analysis
import FemGui
FemGui.setActiveAnalysis(App.ActiveDocument.Analysis)
from femtools import ccxtools
fea = ccxtools.FemToolsCcx()
fea.update_objects()
message = fea.check_prerequisites()
if not message:
    fea.reset_all()
    fea.run()
    fea.load_results()
else:
    FreeCAD.Console.PrintError("Houston, we have a problem! {}\n".format(message))  # in report view
    print("Houston, we have a problem! {}\n".format(message))  # in python console
to get the input file name we do a:
fea.inp_file_name
>>> fea.inp_file_name
'c:\\users\\bha\\appdata\\local\\temp\\Box_Mesh.inp'
give it a try in a file explorer ... for me the file is there.
- ok have got an input file now, let's try to run CalculiX with this input file from FreeCAD.
- I got it working but is is a hack !!!
- close FreeCAD
- change the module ccxtools.py (see after the code block)
- start FreeCAD
- make a new document and add a Analysis (a CcxToolsSolver will be added too)
- run the code (you need to adapt your inputfile)
import FemGui
fea.inp_file_name = 'c:\\users\\bha\\appdata\\local\\temp\\Box_Mesh.inp'
fea.reset_all()  # restes only FreeCAD objects, not result file from CalculiX, better to make sure there is no result file enymore !!!
fea.run()
code change in ccx tools.
https://github.com/FreeCAD/FreeCAD/blob ... #L172-L174
to
        message = ''  # self.check_prerequisites()
        if not message:
            # self.write_inp_file()
EkaitzEsteban
Postby EkaitzEsteban » Tue Sep 25, 2018 8:27 am
# run the analysis
import FemGui
if not message:
    fea.reset_all()
    fea.run()
    fea.load_results()
else:
fea.inp_file_name
>>> fea.inp_file_name
- close FreeCAD
- start FreeCAD
import FemGui
fea.run()
to
        if not message:
Awesome! Another way to do that. It is fantastic
Best regards,
Ekaitz.
EkaitzEsteban
Re: [SOLVED] Run calculix from python API using a previously written .inp file
Postby EkaitzEsteban » Tue Sep 25, 2018 9:27 am
I mix both solutions for adding a new functionality to ccxtools.py without hack in.
I add the following function to ccxtools.py for custom runs using your own .inp files.
def myrun(self):
        ret_code = 0
        message = self.check_prerequisites()
        if not message:
            from FreeCAD import Base
            progress_bar = Base.ProgressIndicator()
            progress_bar.start("Running CalculiX ccx...", 0)
            ret_code = self.start_ccx()
            self.finished.emit(ret_code)
            progress_bar.stop()
            if ret_code or self.ccx_stderr:
                FreeCAD.Console.PrintError("CalculiX failed with exit code {}\n".format(ret_code))
                FreeCAD.Console.PrintMessage("--------start of stderr-------\n")
                FreeCAD.Console.PrintMessage(self.ccx_stderr)
                FreeCAD.Console.PrintMessage("--------end of stderr---------\n")
                FreeCAD.Console.PrintMessage("--------start of stdout-------\n")
                FreeCAD.Console.PrintMessage(self.ccx_stdout)
                self.has_for_nonpositive_jacobians()
                FreeCAD.Console.PrintMessage("--------end of stdout---------\n")
            else:
                FreeCAD.Console.PrintMessage("CalculiX finished without error\n")
        else:
            FreeCAD.Console.PrintError("CalculiX was not started due to missing prerequisites:\n{}\n".format(message))
Now ccxtools.py has two ways for performing a FEM calculus.
1) Usual way. FreeCAD writes the .inp file and it will run the analysis. Type the following commands in python API:
### Run analysis - FreeCAD writes the .inp file and then call calculix
FemGui.setActiveAnalysis(FreeCAD.getDocument("SimpleBox").Analysis)
if not message:
    fea.reset_all()
    fea.run()
    fea.load_results()
else:
2) Custom way. Include in fea.inp_file_name the path of your inp file and then call fea.myrun() new function. Type the following commands in python API:
### Run custom analysis - FreeCAD call calculix using your custom .inp file
fea.inp_file_name ='C:\\filepath\\custom.inp'  # this .inp file must be correctly written (I think that ccxtools.py is unable to check that.)
if not message:
    fea.reset_all()
    fea.myrun() # calls def myrun(self): function defined in ccxtools.py
    fea.load_results()
else:
Both options are available without hacking the program :P ;)
Thank you bernd for your help. This works perfectly without changing the current functionality of FreeCAD :mrgreen: .
Tested in:
Version: 0.17.13528 (Git)
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Python version: 2.7.14
OCC version: 7.2.0
Locale: Spanish/Spain (es_ES)
bernd
Postby bernd » Tue Sep 25, 2018 10:51 am
Ahh, yes your one is better than my hack. Still it is no smart enough to integrate in FreeCAD master!
We should change the run def to be able to run without a precheck and without the inputfile write. In such a case we should even be able to run without a solver object. May be the new solver frame work does the trick much more simpler. I may have a look at all this.
bernd
bernd
Postby bernd » Tue Sep 25, 2018 10:53 am
bernd
Postby bernd » Fri Mar 01, 2019 3:29 pm
should be possible without test mode just by setting the input file name since git commit 3f8c524
