File conversion expertise
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
Bruce Ryan
Postby Bruce Ryan » Mon Oct 01, 2018 8:58 pm
Require FreeCAD expert to convert a 10mb .IGS file to an Autocad .DWG or .DFX file.
Re: File conversion expertise
Postby chrisb » Mon Oct 01, 2018 10:02 pm
Hi Bruce, welcome to the forum.
You can import IGES. AFIK you can export only 2D DXF.
Bruce Ryan
Postby Bruce Ryan » Mon Oct 01, 2018 11:59 pm
And this is beyond my expertise. Interested in helping out?
My interest is in advancing the project, not learning CAD systems. We are involved in a design project. I need additional work done to advance the project.
NormandC
Postby NormandC » Tue Oct 02, 2018 12:24 am
Assuming the IGS file contains 3D data, FreeCAD cannot export 3D data to DWG nor to DXF, if "DFX" was a typo. A commercial program is needed.
sgrogan
Postby sgrogan » Tue Oct 02, 2018 1:36 am
See here: https://forum.freecadweb.org/viewtopic.php?f=8&t=30601 .sat is a 3D .dxf, sortof :?
Bruce Ryan
Postby Bruce Ryan » Tue Oct 02, 2018 4:12 pm
It is definitely a 3-D model of an agricultural processing machine. Can you suggest a solution?
NormandC
Postby NormandC » Wed Oct 03, 2018 4:38 am
You need to find someone with access to a commercial program that can import IGS and export to 3D DWG/DXF.
I have access to commercial CAD software at work and I'm willing to give it a shot if it doesn't take too long, but I can't export to 3D DWG/DXF, only to SAT. AutoCAD can import ACIS (*.sat) files, if that's the software being used.
anna
Postby anna » Wed Oct 03, 2018 8:38 am
Hi Bruce,
Please check your PM.
BR,
Anna
