OOFem
Walgri
OOFem
Post by Walgri »
I wonder if the OOFem finite element code has been evaluated for a possible support in FreeCAD: http://www.oofem.org/
For what I can see in the manual, it seems that this solver may be well suited for civil/structural engineering : http://www.oofem.org/en/manual
PrzemoF
Re: OOFem
Post by PrzemoF »
https://www.freecadweb.org/wiki/FEM_Solver#OOFEM
I guess someone with some coding skills (python should be enough) and interest to see OOFEM support implemented needs to do it. We'll give you all possible support if you want to do it.
Re: OOFem
Post by Kunda1 »
Walgri wrote: Tue Oct 02, 2018 8:29 am For what I can see in the manual, it seems that this solver may be well suited for civil/structural engineering : http://www.oofem.org/en/manual
Joel_graff wrote:
Ping @Joel_graff
You may be interested in this thread
bernd
Re: OOFem
Post by bernd »
the solver frame work of FreeCAD FEM is well suited for easily adding new solvers. It could be all done with Python. I happly support anyone who would like to implement a new solver.
Walgri
Re: OOFem
Post by Walgri »
Thank you guys !
I'll need to inspect more closely this solver and become proficient in plain OOFem before embarking in such a project.
HarryvL
Re: OOFem
Post by HarryvL »
This looks really interesting !! It has interface elements (see https://forum.freecadweb.org/viewtopic. ... 20#p260275) as well as arc-length control (see https://forum.freecadweb.org/viewtopic. ... rc#p215325). In addition many non-linear material models. Well worth further consideration !!
bernd
Re: OOFem
Post by bernd »
but it seams used by very vrry few people. Just try google calculix and pictures. There are lots of models from various internet resources. Try the same with oofem, nearly no screen of a model at all, only scientific diagramms ...
HarryvL
Re: OOFem
Post by HarryvL »
Yeah it's a bit academic, but I will give it a try nonetheless. At first sight it is more suitable for 3D structural collapse analysis than Calculix.
HarryvL
Re: OOFem
Post by HarryvL »
HarryvL wrote: Thu Oct 04, 2018 5:02 pm Yeah it's a bit academic, but I will give it a try nonetheless. At first sight it is more suitable for 3D structural collapse analysis than Calculix.
Well, I gave it a try and first impression ABSOLUTELY PHENOMENAL !
Installation and building from git repository was super simple. The 278 test cases ran first time, without a glitch. The file format is clean and easy to understand. The manual is crystal clear. Export to VTK worked first time around.
Here an example of a plane stress concrete beam under 3 point load, with a notch to initiate cracking. Concrete cracking is simulated with a so-called smeared crack model. Convergence was impressive.
This is definitely worth integrating with FreeCAD and I am willing to spend some serious time on that.
HarryvL
Re: OOFem
Post by HarryvL »
And some more ... Sigma_xx shows tensile zone moving upward, reducing the internal moment lever and therefore causing global softening of the response.
