OOFem
bernd
Re: OOFem
Postby bernd » Thu Nov 01, 2018 4:45 pm
I will have a look.
bernd
Re: OOFem
Postby bernd » Thu Nov 01, 2018 5:10 pm
They will be assigned if needed ...
For example for the CalculiX mesh they are not needed. Thus for calculix they are only needed for constraints like force or pressure, thus they are assigned inside each constraint writer. For example on calculix frequency analysis without constraints they are not needed at all. Z88 needs them for mesh writing too. Means they are needed for any input file writing. Thus they are assigned just at start of writing. They are assigned here: https://github.com/HarryvL/FreeCAD/blob ... py#L66-L69
Means for oofem your would copy the lines from above to https://github.com/HarryvL/FreeCAD/blob ... ter.py#L75 if you need them in any file write (which will be true if you need them for mesh writing).
hope that helps bernd
HarryvL
Re: OOFem
Postby HarryvL » Thu Nov 01, 2018 7:50 pm
Thanks. I will give it a try.
bernd
Re: OOFem
Postby bernd » Thu Nov 01, 2018 8:39 pm
BTW: Does oofem has its own mesh format like Z88? If it would support any of the known standard mesh format FreeCAD supports already you would not need to write a mesh exporter for oofem in FreeCAD like I had to do it for Z88.
Bernd
HarryvL
Re: OOFem
Postby HarryvL » Thu Nov 01, 2018 9:57 pm
AFAIK the mesh information is typed in the input file in a connectivity format (global node numbers by element) unique to OOFEM. The developers make available a converter script (unv2oofem) that turns UNV files into OOFEM format, but going via UNV would be a roundabout way to get to the required result. Not sure this answers your question.
HarryvL
Re: OOFem
Postby HarryvL » Thu Nov 01, 2018 10:19 pm
PS: what standard mesh format does CCX use and how is this written to the input file?
bernd
Re: OOFem
Postby bernd » Fri Nov 02, 2018 6:20 am
ccx uses Abaqus inp file format. It is written here: https://github.com/berndhahnebach/FreeC ... ter.py#L82 The writer ist done in C++ see https://github.com/berndhahnebach/FreeC ... .cpp#L1185
Some Formats are done in C++ See https://github.com/berndhahnebach/FreeC ... .cpp#L1575
to write a mesh in various formats just load the 3D example from Start WB
expath = '/home/hugo/Desktop/'
mesh = App.ActiveDocument.Box_Mesh.FemMesh
mesh.write(expath + 'mesh.inp')
mesh.write(expath + 'mesh.vtk')
mesh.write(expath + 'mesh.stl')
mesh.write(expath + 'mesh.unv')
for Z88 you would need to import the Python module first ...
from feminout.importZ88Mesh import export as z88export
z88export([App.ActiveDocument.Box_Mesh], expath + 'mesh.txt')
The z88 one should be improved to be as easy as the c++ ones. But this is of low priority for me. Ahh element table and nodes are retrieved in the export def see: https://github.com/berndhahnebach/FreeC ... py#L73-L75
bernd
Re: OOFem
Postby bernd » Fri Nov 02, 2018 6:23 am
similar to z88. They have a converter too. My first idea was use the converter, but than I realised to write an exporter just for nodes and tet10 elements is not difficult and just some lines of code. With this one can export lots of analysis already. All other element types where added step by step later on.
cheers bernd
HarryvL
Re: OOFem
Postby HarryvL » Fri Nov 02, 2018 6:32 am
cheers bernd
That's exactly the thought process I went through for OOFEM :D
bernd
Re: OOFem
Postby bernd » Fri Nov 02, 2018 7:49 am
8-)
