Baffle / Pressure loss
Moderator: oliveroxtoby
suRe
Postby suRe » Thu Oct 04, 2018 3:53 pm
Hey everybody,
can someone explain to me, how the fluid boundary "baffle" works and how it is correctly applied in FreeCAD/CfdOF.
What i would like to do is the following simple example:
I modelled a straight pipe (3000 mm long, 150 mm diameter) in which a perforated plate would be installed (currently through a second .stp File in the middle of the pipe). Since i don't want to mesh every whole of the plate, i tried adding a fixed value for pressure loss (selected the face of the second .stp File), but OF quits with errors. Is there any example on how to implement a pressure loss?
Thank you for any help!
suRe
Re: Baffle / Pressure loss
Postby suRe » Thu Oct 04, 2018 6:55 pm
Well, f*ck me! On the tutorial page (opensim) is pretty much exactly the kind of example i was looking for the last 3 days.
For anyone who is looking for this particular problem in the future, here is the link.
https://github.com/opensimsa/opensim/tr ... PorousFlow
Case closed :-)
suRe
Postby suRe » Fri Oct 05, 2018 2:59 pm
Hey guys,
i got to revise my last comment. The example I mentioned works perfect for meshing with gmsh, but with cfmesh i just can't get it to run.
Could someone help me? Attached you will find the file.
rohr2.FCStd
(52.7 KiB) Downloaded 19 times
oliveroxtoby
Postby oliveroxtoby » Fri Oct 05, 2018 3:10 pm
Hey guys,
cfMesh doesn't support baffles and internal regions, so snappyHexMesh must be used. Please note there are separate tutorials for snappy and gmsh - the geometry has to be set up a bit differently for the two.
Please provide all the information requested in this post before reporting problems with CfdOF.
suRe
Postby suRe » Fri Oct 05, 2018 3:43 pm
Oh.. okay :( Too bad, i really like the meshes cfmesh generates. Even in bigger models with thousands of faces the mesh quality is very good for a free mesher. Will they be adding such a feature?
