Hmm, not sure, but I would hesitate to install one of the .deb files from the PPA. Normally I would recommend just cloning the package source repository (https://salsa.debian.org/kkremitzki-guest/calculix-ccx) and building it but the package is set up in a bit of a strange way that breaks if you don't use git-buildpackage which requires some dotfiles to behave correctly.
If you're feeling adventurous you could try this:
1. Create a file ~/.gbp.conf with these contents: https://wiki.debian.org/PackagingWithGi ... e_gbp.conf
2. Run sudo apt install git-buildpackage
3. Run gbp clone --all https://salsa.debian.org/kkremitzki-guest/calculix-ccx
4. Run cd calculix-ccx && gbp buildpackage -us -uc
Edit: You may also want to modify the ~/.gbp.conf I linked, particularly the postbuild line:
postbuild = lintian -iIE --pedantic $GBP_CHANGES_FILE && echo "Lintian OK""" || echo "Lintian NOT OK" && true
