0001304: Allow Sketcher to Fillet Arcs, Not Only Lines
Re: 0001304: Allow Sketcher to Fillet Arcs, Not Only Lines
Postby chrisb » Sun Oct 21, 2018 8:12 am
You don't have to do all the testing yourself. As soon as you are confident enough, roll it out and wait for the feedback. From the echo here, there are enough testers around.
bejant
Postby bejant » Sun Oct 21, 2018 2:44 pm
abdullah wrote:
Sun Oct 21, 2018 6:49 am
Look at the endpoint of the major axis of the left ellipse. It does move slightly when applying the tangency.
I don't see the movement either...
I don't think it's unreasonable for an unconstrained endpoint to move a tiny bit after the Fillet is applied, and I'm pretty sure that behavior existed before. I think your changes should be merged, and we can report back to you regarding any issues we might find.
abdullah
Postby abdullah » Tue Oct 23, 2018 3:22 pm
Ok. I see you all are eager. I am going to do some tests and will ask Werner about when to merge.
Postby chrisb » Tue Oct 23, 2018 6:12 pm
You shouldn't take the moving too serious, things move all the time in sketcher as long as the sketch is not fully constraint. I see that it would be nice not to move in this case, but there is no need for it.
abdullah
Postby abdullah » Wed Oct 24, 2018 6:24 am
I am no longer considering moving as an issue. B-Splines will move, but I think this is normal.
I am trying to clean up the code and make some meaningful messages for the user, as:
Postby Kunda1 » Wed Oct 24, 2018 10:59 am
@abdullah is there a way to tell Qt to create a popup that doesn't cease operations till you press 'OK' ?
Instead it either stays open and less conspicuous (to the side) or even dissolves after a certain time threshold is reached ?
abdullah
Postby abdullah » Fri Oct 26, 2018 2:09 pm
Not to my knowledge.
Another task for the idea of the "clipper"-alike assistant. ;)
Postby Kunda1 » Fri Oct 26, 2018 3:39 pm
@abdullah Did you ever hear/see the tragic story of what happened to Clippy? :lol:
https://i.gifer.com/Axob.gif (it's an animated gif and I wanted to save data for mobile users)
abdullah
Postby abdullah » Fri Oct 26, 2018 5:08 pm
Poor thing...
It seems you trying to make a fillet...
we could always task "Rocky" with it.
