Understanding GeomAPI_ExtremaCurveCurve
abdullah
Postby abdullah » Sun Oct 21, 2018 5:17 am
Hi there!
I am not sure I am understanding this algorithm properly.
We use this algorithm, for example for intersections between two curves:
bool GeomCurve::intersect(  GeomCurve * c,
                            std::vector<std::pair<Base::Vector3d, Base::Vector3d>>& points,
                            double tol) const
    Handle(Geom_Curve) curve1 = Handle(Geom_Curve)::DownCast(handle());
    Handle(Geom_Curve) curve2 = Handle(Geom_Curve)::DownCast(c->handle());
    try {
        if(!curve1.IsNull() && !curve2.IsNull()) {
            GeomAPI_ExtremaCurveCurve intersector(curve1, curve2);
            if (intersector.NbExtrema() == 0 || intersector.LowerDistance() > tol) {
                // No intersection
                return false;
            for (int i = 1; i <= intersector.NbExtrema(); i++) {
                if (intersector.Distance(i) > tol)
                    continue;
                gp_Pnt p1, p2;
                intersector.Points(i, p1, p2);
                points.emplace_back(Base::Vector3d(p1.X(),p1.Y(),p1.Z()),Base::Vector3d(p2.X(),p2.Y(),p2.Z()));
            return points.size()>0?true:false;
        else
            return false;
    catch (Standard_Failure& e) {
        throw Base::RuntimeError(e.GetMessageString());
I filed a bug report with OCCT recently:
https://tracker.dev.opencascade.org/view.php?id=30217
I have found other cases where I get no result, and I am starting to think that maybe it is me, that I do not know how to use it, and not the algorithm.
The new case is this:
There is a coincidence between the arc of circle and the line segment.
I have a stand alone c++ example where the intersection is not detected:
# include <Geom_Circle.hxx>
# include <Geom_Curve.hxx>
# include <Geom_Line.hxx>
# include <Geom_Plane.hxx>
# include <GC_MakeCircle.hxx>
# include <GC_MakeSegment.hxx>
# include <GC_MakeArcOfCircle.hxx>
# include <gp.hxx>
# include <gp_Ax2.hxx>
# include <gp_Pnt.hxx>
# include <gp_Dir.hxx>
# include <gp_Pln.hxx>
# include <gp_Circ.hxx>
# include <GeomAPI.hxx>
# include <Geom2d_Curve.hxx>
# include <Geom2dAPI_InterCurveCurve.hxx>
# include <GeomAPI_ExtremaCurveCurve.hxx>
int main()
    double precision = 1.0e-8;
    // A line segment
    gp_Pnt p1(-15.625722, -10.526889000000001, 0.0), p2(-16.296861005504617, -7.746175, 0.0);
    GC_MakeSegment ms(p1, p2);
    Handle(Geom_TrimmedCurve) tc_line = ms.Value();
    // A circunference arc
    gp_Pnt center(-16.614095762607519, -9.1963880000000007, 0.0);
    double radius = 1.4845051823698976;
    double StartAngle = 1.3554381905682238;
    double EndAngle = 2.446854102374213;
    gp_Dir norm(0,0,1);
    gp_Ax2 xdir(center, norm);
    GC_MakeCircle mc(xdir, radius);
    Handle(Geom_Circle) circle = mc.Value();
    GC_MakeArcOfCircle ma(mc.Value()->Circ(), StartAngle, EndAngle, 1);
    if (!ma.IsDone()) {
        printf("Unable to create arc!!");
        return -1;
    Handle(Geom_TrimmedCurve) arc = ma.Value();
    // NOTE: Non-tangent line with coincident endpoint
    double distance_endpoint_linesegment_startpoint_arc = arc->StartPoint().Distance(tc_line->EndPoint());
    printf("SETUP:\n");
    printf("========\n");
    printf("Description: Arc of Circle with coincident line endpoint\n\n");
    printf("Distance from endpoint of line segment to startpoint of arc: %e\n", distance_endpoint_linesegment_startpoint_arc);
    GeomAPI_ExtremaCurveCurve Intersector3d(arc, tc_line);
    printf("\tGeomAPI_ExtremaCurveCurve - NbExtrema: %d\n", Intersector3d.NbExtrema());
    return 0;
Output:
SETUP:
Distance from endpoint of line segment to startpoint of arc: 1.953993e-14
        GeomAPI_ExtremaCurveCurve - NbExtrema: 0
I have checked the documentation, there is a part I may not fully understand:
Describes functions for computing all the extrema between two 3D curves. An ExtremaCurveCurve algorithm minimizes or maximizes the distance between a point on the first curve and a point on the second curve. Thus, it computes start and end points of perpendiculars common to the two curves (an intersection point is not an extremum unless the two curves are tangential at this point). Solutions consist of pairs of points, and an extremum is considered to be a segment joining the two points of a solution.
Anybody familiar with this algorithm can help me out here? Is it a bug or is it me?
ezzieyguywuf
Re: Understanding GeomAPI_ExtremaCurveCurve
Postby ezzieyguywuf » Mon Oct 22, 2018 3:51 am
I'm not familiar with this algorithm specifically, but I am familiar with tangents. per the Wikipedia description "in geometry, the tangent line (or simply tangent) to a plane curve at a given point is the straight line that "just touches" the curve at that point"
The line you have drawn does not appear to be tangential to the curve. Rather, it appears to intersect the curve. Therefore, per the documentation of this class, it doesn't seem this point would be considered an extrema.
Can you describe what you're trying to accomplish?
Chris_G
Postby Chris_G » Mon Oct 22, 2018 8:39 am
I tried your example in python, and it fails also.
It looks like a tolerance problem.
I get a distance of about 2e-14 between the "coincident" points.
The algo seems to fail for distance > 1e-15
See the code below :
import FreeCAD
import Part
v = FreeCAD.Vector
center = v(-16.614095762607519, -9.1963880000000007, 0.0)
norm = v(0,0,1)
circ = Part.Circle(center, norm, radius)
arc = Part.ArcOfCircle(circ, StartAngle, EndAngle)
p1 = v(-15.625722, -10.526889000000001, 0.0)
p2 = v(-16.296861005504617, -7.746175, 0.0)
# ls = Part.LineSegment(p1,p2) # FAILS (dist = 1.95e-14)
ls = Part.LineSegment(p1,arc.value(arc.FirstParameter)) # WORKS
# ls = Part.LineSegment(p1,arc.value(arc.FirstParameter)+v(1e-15,0,0)) # WORKS
# ls = Part.LineSegment(p1,arc.value(arc.FirstParameter)+v(2e-15,0,0)) # FAILS again
pts = arc.intersectCC(ls)
com = Part.Compound([p.toShape() for p in pts])
Part.show(ls.toShape())
Part.show(arc.toShape())
Part.show(com)
abdullah
Postby abdullah » Tue Oct 23, 2018 3:29 pm
I am detecting intersections between curves.
I was puzzled about the endpoints for a while. While the definition of intersection is having one point in common, the Extrema algorithm, seems to require this tangency. This seems to be ok for the points comprised but not including the end and start points, as you need the tangency to define a change, from increasing distance among two curves to decreasing or vice versa.
My conclusion is that the using extrema to detect intersection is fine as far as we are not considering the start and endpoints. I have treated this as a bug in the intersection routine, adding some extra code to additionally consider the start and endpoints outside the Extrema algorithm.
Thanks for reading! :)
abdullah
Postby abdullah » Tue Oct 23, 2018 3:32 pm
With the "fixed" bug, all the example now work (in my local copy of FreeCAD).
Thanks for taking the time :)
abdullah
Postby abdullah » Sat Oct 27, 2018 3:58 pm
Hi folks!
I am finding some even more difficult to explain behaviour regarding GeomAPI_ExtremaCurveCurve.
I think I have a case where two continues curves do intersect at 2 points that are NOT the endpoints, and the algorithm only reports 1.
I would not like to make the people of OCCT lose their time miserably, so I would appreciate if somebody could take the values of the output of the c++ example below (I post the output, so no need to compile), draw it in paper and make sure that the "offset curves" intersect at two points.
I have invested almost a week trying to get the best examples for them to try and I think this one is the best I can offer.
The situation:
I am trying to trim this two arcs of ellipse (but the intersection I talk about above is not what you see, bear with me). For that, I calculate two offset curves that cannot be shown in FreeCAD, because the sketcher does not have support for Offsetcurves, but that should look something like this:
You have to imagine that those construction ellipses maintain a same distance with the non-construction ones, so the intersection is the center of the fillet with radius the offset value.
In the output below you can see, a succession of points (x,y,0) for the two normal ellipses above first, and then for the construction (the offset arcs of ellipse). What the code calculates should be the intersection between the offset curves.
The code detects the bottom intersection, but not the top one. Within the code, I have also pasted the output as a comment and marked where I see both intersections. Maybe I am just too tired.
It would be great if somebody can take a look.
The output:
OUTPUT VALUES OF THE CURVES:
Arc of Ellipse 1 :
3.749540: (-7.275644,-2.246404,0)
4.256173: (-8.422482,-1.084028,0)
4.762806: (-9.997476,-0.612632,0)
5.269439: (-11.604936,-0.950647,0)
5.776072: (-12.841013,-2.013152,0)
6.282705: (-13.395164,-3.533211,0)
6.789338: (-13.128167,-5.128934,0)
7.295971: (-12.107101,-6.399421,0)
7.802604: (-10.588492,-7.025484,0)
8.309237: (-8.953866,-6.849835,0)
8.815870: (-7.613894,-5.916603,0)
Arc of Ellipse 2 :
3.427630: (-7.613843,-5.916620,0)
3.946857: (-6.363137,-7.268858,0)
4.466084: (-4.565407,-7.837935,0)
4.985311: (-2.694522,-7.473846,0)
5.504538: (-1.243637,-6.272562,0)
6.023765: (-0.595196,-4.550735,0)
6.542992: (-0.920124,-2.762228,0)
7.062219: (-2.132772,-1.378480,0)
7.581446: (-3.913494,-0.764240,0)
8.100673: (-5.792902,-1.081417,0)
8.619900: (-7.275595,-2.246405,0)
Offset Arc of Ellipse 1 :
3.749540: (-6.100171,-1.565646,0)
4.256173: (-7.723394,0.080638,0)
4.762806: (-9.940595,0.744547,0)
5.269439: (-12.205122,0.267937,0)
5.776072: (-13.957389,-1.239283,0)
6.282705: (-14.747802,-3.408550,0)
6.789338: (-14.367174,-5.685738,0)
7.295971: (-12.919871,-7.487803,0)
7.802604: (-10.780575,-8.370205,0)
8.309237: (-8.479384,-8.122642,0)
8.815870: (-6.582633,-6.800723,0)
Offset Arc of Ellipse 2 :
3.427630: (-8.819565,-6.542242,0)
3.946857: (-7.087416,-8.418028,0)
4.466084: (-4.641189,-9.194190,0)
4.985311: (-2.115470,-8.702613,0)
5.504538: (-0.140323,-7.064943,0)
6.023765: (0.757442,-4.675394,0)
6.542992: (0.302230,-2.169759,0)
7.062219: (-1.378655,-0.248668,0)
7.581446: (-3.803608,0.589678,0)
8.100673: (-6.340850,0.161532,0)
8.619900: (-8.357785,-1.425408,0)
Calculate intersection of offset curves
GeomAPI_ExtremaCurveCurve NbExtrema = 1
        Extrema nr 1: (-7.845691,-7.830647,0.000000),(-7.845691,-7.830647,0.000000)
The code:
# include <Geom_Ellipse.hxx>
# include <Geom_TrimmedCurve.hxx>
# include <Geom_OffsetCurve.hxx>
# include <GC_MakeEllipse.hxx>
# include <GC_MakeArcOfEllipse.hxx>
# include <gp.hxx>
# include <gp_Elips.hxx>
int main()
    // A first arc of ellipse
    // ArcOfEllipse (MajorRadius : 3.28231, MinorRadius : 3.22419, AngleXU : 3.05018,
    // Position : (-10.1267, -3.83438, 0), Direction : (0, 0, 1), Parameter : (3.74954, 8.81587))
    gp_Pnt p1(-10.1267,-3.83438,0);
    gp_Dir norm(0,0,1);
    gp_Ax1 normaxis(p1,norm);
    gp_Ax2 xdir(p1, norm);
    xdir.Rotate(normaxis,3.05018);
    GC_MakeEllipse mc(xdir, 3.28231, 3.22419);
    if (!mc.IsDone()) {
	printf("First ellipse not done");
	return -1;
    GC_MakeArcOfEllipse ma(mc.Value()->Elips(), 3.74954, 8.81587, 1);
    if (!ma.IsDone()) {
    	printf("First arc of ellipse not done");
	return -1;
    Handle(Geom_TrimmedCurve) aoe1 = ma.Value();
    // A second arc of ellipse
    // ArcOfEllipse (MajorRadius : 3.7124, MinorRadius : 3.54058, AngleXU : 0.179513,
    // Position : (-4.28788, -4.29777, 0), Direction : (0, -0, 1), Parameter : (3.42763, 8.6199))
    gp_Pnt p2(-4.28788, -4.29777, 0);
    gp_Dir norm2(0,0,1);
    gp_Ax1 normaxis2(p2,norm2);
    gp_Ax2 xdir2(p2, norm2);
    xdir2.Rotate(normaxis2, 0.179513);
    GC_MakeEllipse mc2(xdir2, 3.7124, 3.54058);
    if (!mc2.IsDone()){
        printf("Second ellipse not done");
	return -1;
    GC_MakeArcOfEllipse ma2(mc2.Value()->Elips(), 3.42763, 8.6199, 1);
    if (!ma2.IsDone()){
        printf("Second arc of ellipse not done");
	return -1;
    Handle(Geom_TrimmedCurve) aoe2 = ma2.Value();
    // TEST SETUP: OUTPUT CURVES
    printf("\nOUTPUT VALUES OF THE CURVES:\n");
    auto printcurve = [](Handle(Geom_Curve) c, char const* title) {
	printf("\n%s :\n",title);
    	for(double param = c->FirstParameter(); param < c->LastParameter(); param = param + (c->LastParameter()-c->FirstParameter())/10)
        	printf("%f: (%f,%f,0)\n", param, c->Value(param).X(),c->Value(param).Y());
      	printf("%f: (%f,%f,0)\n", c->LastParameter(), c->Value(c->LastParameter()).X(),c->Value(c->LastParameter()).Y());
    printcurve(aoe1,"Arc of Ellipse 1");
    printcurve(aoe2,"Arc of Ellipse 2");
    // Construct Offset curves from the Arc of Ellipses
    double offset = 1.358370;
    gp_Dir norm3(0,0,1);
    Handle(Geom_OffsetCurve) oaoe1 = new Geom_OffsetCurve(aoe1, offset, norm3);
    Handle(Geom_OffsetCurve) oaoe2 = new Geom_OffsetCurve(aoe2, offset, norm3);
    printcurve(oaoe1,"Offset Arc of Ellipse 1");
    printcurve(oaoe2,"Offset Arc of Ellipse 2");
    // From the output, there are two intersections:
	//Offset Arc of Ellipse 1 :
	//3.749540: (-6.100171,-1.565646,0) <= Cross 1 of offset curves
	//4.256173: (-7.723394,0.080638,0)  <= Cross 1 of offset curves
	//4.762806: (-9.940595,0.744547,0)
	//5.269439: (-12.205122,0.267937,0)
	//5.776072: (-13.957389,-1.239283,0)
	//6.282705: (-14.747802,-3.408550,0)
	//6.789338: (-14.367174,-5.685738,0)
	//7.295971: (-12.919871,-7.487803,0)
	//7.802604: (-10.780575,-8.370205,0)
	//8.309237: (-8.479384,-8.122642,0) <= Cross 2 of offset curves
	//8.815870: (-6.582633,-6.800723,0) <= Cross 2 of offset curves
	//Offset Arc of Ellipse 2 :
	//3.427630: (-8.819565,-6.542242,0) <= Cross 2 of offset curves
	//3.946857: (-7.087416,-8.418028,0) <= Cross 2 of offset curves
	//4.466084: (-4.641189,-9.194190,0)
	//4.985311: (-2.115470,-8.702613,0)
	//5.504538: (-0.140323,-7.064943,0)
	//6.023765: (0.757442,-4.675394,0)
	//6.542992: (0.302230,-2.169759,0)
	//7.062219: (-1.378655,-0.248668,0)
	//7.581446: (-3.803608,0.589678,0)
	//8.100673: (-6.340850,0.161532,0)  <= Cross 1 of offset curves
	//8.619900: (-8.357785,-1.425408,0) <= Cross 1 of offset curves
    // Calculate intersection of offset curves
    printf("\nCalculate intersection of offset curves\n");
    GeomAPI_ExtremaCurveCurve intersector(oaoe1, oaoe2);
    if (intersector.NbExtrema() == 0 || intersector.LowerDistance() > precision) {
    	// No intersection
	printf("\nNo intersection between offset curves\n");
        return -1;
    printf("\nGeomAPI_ExtremaCurveCurve NbExtrema = %d\n",intersector.NbExtrema());
        if (intersector.Distance(i) > precision)
            continue;
        gp_Pnt p1, p2;
	printf("\tExtrema nr %d: (%f,%f,%f),(%f,%f,%f)\n",i,p1.X(),p1.Y(),p1.Z(),p2.X(),p2.Y(),p2.Z());
    return 0;
Compiling, if you want to do tests:
g++ intersector3.cpp -I/usr/include/occt -L/usr/lib/x86_64-linux-gnu -lTKG3d -lTKernel -lTKMath -lTKGeomBase -lTKGeomAlgo -o intersector3
Postby chrisb » Sat Oct 27, 2018 5:55 pm
Sorry for not being able to help with the code. I have tried to remodel your example, assuming that you use the same functions available in sketcher, and I thought the intersections might fail as well - which they did not!
Next I wanted to create a fillet, you see it at the lower intersection. I have already point-on-object constraints and now I wanted to create tangents on top of them (this was merely to test the "remove redundants" code). And there something strange happens: If I select the elements as in the image and apply tangency, then the tangent is added to the list of constraints as expected, but nothing happens in 3D view, DOF remains as before, solver message doesn't change, elements are not made tangent.
Bildschirmfoto 2018-10-27 um 19.45.59.png (32.46 KiB) Viewed 1106 times
ellipticIntersections.FCStd
(4.71 KiB) Downloaded 13 times
abdullah
Postby abdullah » Sun Oct 28, 2018 6:36 am
No worries. Yesterday I was way too tired. Today, with a fresh mind, I used sage to plot the curves. I post the sage math code in case somebody is interested at the end of the post. In got this graph:
So yes, the curves do intersect. I am going to file a new bug ticket with OCCT. I hope I am not just loading them with work because of my ineptitude.
I will take a look now...
aoe1 = [[-7.275644,-2.246404],[-8.422482,-1.084028],[-9.997476,-0.612632],[-11.604936,-0.950647],[-12.841013,-2.013152],[-13.395164,-3.533211],[-13.128167,-5.128934],[-12.107101,-6.399421],[-10.588492,-7.025484],[-8.953866,-6.849835],[-7.613894,-5.916603]]
paoe1 = line(aoe1, rgbcolor=(1/4,1/8,3/4))
aoe2 = [[-7.613843,-5.916620],[-6.363137,-7.268858],[-4.565407,-7.837935],[-2.694522,-7.473846],[-1.243637,-6.272562],[-0.595196,-4.550735],[-0.920124,-2.762228],[-2.132772,-1.378480],[-3.913494,-0.764240],[-5.792902,-1.081417],[-7.275595,-2.246405]]
paoe2 = line(aoe2, rgbcolor=(1/4,1/8,3/4))
oaoe1 = [[-6.100171,-1.565646],[-7.723394,0.080638],[-9.940595,0.744547],[-12.205122,0.267937],[-13.957389,-1.239283],[-14.747802,-3.408550],[-14.367174,-5.685738],[-12.919871,-7.487803],[-10.780575,-8.370205],[-8.479384,-8.122642],[-6.582633,-6.800723]]
opaoe1 = line(oaoe1, rgbcolor=(3/4,1/8,1/4))
oaoe2 = [[-8.819565,-6.542242],[-7.087416,-8.418028],[-4.641189,-9.194190],[-2.115470,-8.702613],[-0.140323,-7.064943],[0.757442,-4.675394],[0.302230,-2.169759],[-1.378655,-0.248668],[-3.803608,0.589678],[-6.340850,0.161532],[-8.357785,-1.425408]]
opaoe2 = line(oaoe2, rgbcolor=(3/4,1/8,1/4))
g = paoe1+paoe2+opaoe1+opaoe2
g.show(xmin=-15, xmax=5, ymin=-15, ymax=5)
abdullah
Postby abdullah » Sun Oct 28, 2018 6:51 am
abdullah
Postby abdullah » Sun Oct 28, 2018 7:36 am
Well, your intersections are calculated by the sketcher solver, not by OCCT. So it is kindda different.
BUG 1: What you describe is a bug and should be reported to the tracker. Something is clearly wrong. It cannot be that is added and ignored.
BUG 2: Somehow, it may be the same situation as with the "hook" in the german forum. So from a solver point of view it may also go in the direction of reworking the inter-curve-tangency constraint.
In any case, the fillet you were trying to build is a little bit odd, as the fillet, to be tangent, should go to the normal with the curves:
ellipticIntersections_2.FCStd
(5.37 KiB) Downloaded 13 times
However, making this fully constrained has been problematic and in fact, the result is not ok. The center of the fillet should be the intersection between the offset curves, and it is not. In fact the radius of the fillet should be 6mm, but I the blue dimension says 5.8mm.
BUG 3: Therefore there is indeed something weird happening here.
Please, file the 3 tickets with the tracker. There are a lot of rainy days to come... :)
