Error Running AddOnManager in 018.15052
Syres
Postby Syres » Sat Oct 27, 2018 11:29 am
I noticed there was a recent PR https://github.com/FreeCAD/FreeCAD/pull/1740 which shows as Closed. Using both of the following versions, I'm getting the error received below in Report View when trying to start the Addon manager. I was just wondering whether this is still being worked on/actioned? By all means confirm on other platforms and just to note all the Python files quoted below are present.
Running the Python command 'Std_AddonMgr' failed:
  File "E:\Data\My Downloads\FreeCAD_0.18.15052_Conda_Py3QT5-WinVS2015_x64\FreeCAD_0.18.15052_Conda_Py3QT5-WinVS2015_x64\Mod\AddonManager\AddonManagerGui.py", line 10, in Activated
    import AddonManager
  File "E:\Data\My Downloads\FreeCAD_0.18.15052_Conda_Py3QT5-WinVS2015_x64\FreeCAD_0.18.15052_Conda_Py3QT5-WinVS2015_x64\Mod\AddonManager\AddonManager.py", line 54, in <module>
    from addonmanager_macro import Macro
  File "E:\Data\My Downloads\FreeCAD_0.18.15052_Conda_Py3QT5-WinVS2015_x64\FreeCAD_0.18.15052_Conda_Py3QT5-WinVS2015_x64\Mod\AddonManager\addonmanager_macro.py", line 28, in <module>
    from freecad import app
cannot import name 'app'
OS: Windows 7
Version: 0.18.15052 (Git)
Hash: 76590be8aca6b4fed09ec94ada811fa89dbcdbe0
Python version: 2.7.14
OCC version: 7.2.0
OS: Windows 7
Python version: 3.6.6
Qt version: 5.6.2
Re: Error Running AddOnManager in 018.15052
Postby Kunda1 » Sat Oct 27, 2018 12:57 pm
galou wrote:
@galou ping
Site Admin
Postby wmayer » Sat Oct 27, 2018 2:11 pm
I think this is a problem of the AppImage where presumably the freecad directory isn't picked up.
But there is also regression in the PR because it has removed the function get_macro_dir() and replaced its occurrences with FreeCAD.getUserMacroDir(). However, FreeCAD.getUserMacroDir() only returns the path of the default macro directory but not the path of the actual macro directory which a user can change in the preferences/macro dialog.
sgrogan
Postby sgrogan » Sat Oct 27, 2018 2:58 pm
Works for me, with only the problem wmayer pointed out.
OS: Windows 7
Qt version: 5.6.2
yorik
Site Admin
Postby yorik » Sat Oct 27, 2018 7:17 pm
I fixed the "from freecad import app" issue in git commit 57726db47
Shouldn't we change that? Not sure...
Site Admin
Postby wmayer » Sat Oct 27, 2018 7:26 pm
Yes, makes sense as FreeCAD.getUserMacroDir() is quite useless if the user has changed the default path. We could also add an optional parameter to the function and depending on it return the actual or current path.
Site Admin
Postby wmayer » Sun Oct 28, 2018 4:10 pm
yorik
Site Admin
Postby yorik » Sun Oct 28, 2018 4:18 pm
Thanks!
galou_breizh
Postby galou_breizh » Thu Nov 08, 2018 3:55 pm
I think this is not a fix, this is a workaround because `from freecad import app` is a more modern version of `import FreeCAD`. Moreover, `from freecad import app` works on v0.18 with Python 2.
As I wrote (https://github.com/FreeCAD/FreeCAD/commit/17c783051), I would rather have `FreeCAD.getUserMacroDir()` return the actual path and `FreeCAD.getUserMacroDir(False)` return the default path.
Gaël
