Poor man's (single width) slotting
I thought it might be worthwhile to share an example of how one can do single pass slots - today. It has come up a few times and I'm not sure my verbal explanations make that much sense, so here is a screenshot and the file to play with.
For simplicity reasons I just used the default tool. Note that the depth (Z - level) of the two edges does not have to match, you can adjust through the operation parameters.
Also, if you have simple slot (no overhangs) you can use multi passes by using a more sensible "step down" value
- slot.fcstd
- (28.19 KiB) Downloaded 100 times
- sliptonic
Re: Poor man's (single width) slotting
Excellent explanation!
If you don't mind, I might make this the subject of a video.
Great example. I always thought that engraving worked only on ShapeStrings; good to see it works on sketches too. Is it possible to extend it so that it can operate on arbitrary edges too? That would make FromShape obsolete. The latter would probably need much more love to get integrated in the Job concept.
Back to the example: As soon as I select an edge of the sketch I get an error message in report view:After that everything works as expected.
My version is a bit outdated due to Mac compile issues.
OS: macOS High Sierra (10.13)
Version: 0.18.14976 (Git)
Branch: (HEAD detached at e79a19828)
Hash: e79a19828e2e92269ff96110dfeadaa245ad17c2
Python version: 2.7.15
Qt version: 5.11.2
OCC version: 7.2.0
PathCommands.ERROR: Failed to create face from wire
File "/Users/cb/Desktop/FreeCAD.app/Contents/Mod/Path/PathCommands.py", line 73, in IsActive
self.active = self.formsPartOfALoop(sel.Object, sel.SubObjects[0], sel.SubElementNames)
File "/Users/cb/Desktop/FreeCAD.app/Contents/Mod/Path/PathCommands.py", line 114, in formsPartOfALoop
if len(names) == 1 and horizontalEdgeLoop(obj, sub):
File "/Users/cb/Desktop/FreeCAD.app/Contents/Mod/Path/PathScripts/PathUtils.py", line 241, in horizontalEdgeLoop
loops = [w for w in wires if all(PathGeom.isHorizontal(e) for e in w.Edges) and PathGeom.isHorizontal(Part.Face(w))]
OCCError: Failed to create face from wire
Qt version: 5.11.2
OCC version: 7.2.0
No issues in current Ubuntu:
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15099 (Git)
Hash: 1538a14eca0879be3d223930f7e5f78d4a24691c
Python version: 2.7.12
Don't spend your time on that. There is no current MacOS version and the error does not occur in a current (Ubuntu) version.
wohooo!
I got v0.18 working, and now this example just works. This makes life now much easier with more than one object as a base for Job.
Thanks!
Thanks!
@mlampert: How did you get your sketch to show up as 2d feature when creating a new path job? It works fine on your sample file here, but on my own files it only shows solids to select.
My Version Info:
OS: macOS 10.14
Version: 0.18.15363 (Git)
Hash: 9be3e633328335f1172456f5857219b7a08c70a5
Python version: 3.6.7
Qt version: 5.6.2
My Version Info:
OS: macOS 10.14
Qt version: 5.6.2
- Screenshot 2018-12-12 at 12.37.17.png (254.98 KiB) Viewed 2295 times
Just create a Sketch as a root object in the tree. If you post your file I can have a look.leonardshelby wrote: ↑Wed Dec 12, 2018 11:44 am @mlampert: How did you get your sketch to show up as 2d feature when creating a new path job? It works fine on your sample file here, but on my own files it only shows solids to select.
