[DONE] conda: update to gcc7 and py3.7
looo
Re: [wip] conda: update to gcc7 and py3.7
Postby looo » Tue Mar 05, 2019 10:31 pm
Only via conda... I still don't know how to create dmg images and first I would like to port freecad to new compilers...
looo
Postby looo » Wed Mar 06, 2019 2:59 pm
ok, I have created a dmg with this script: https://github.com/FreeCAD/FreeCAD-AppI ... x/conda.sh
Now I have a 360.2mb FreeCAD_conda_clang4.0.1.dmg file. The only thing missing is the upload... I guess I need special Github-Rights for this task.
@sgrogan @triplus
looo
Postby looo » Wed Mar 06, 2019 3:23 pm
ok, I guess there is not much missing for weekly osx-builds. Maybe someone else can have a look at these points.
1. automatic naming of the dmg:
https://github.com/looooo/FreeCAD-AppIm ... nda.sh#L45
2. automatic upload to the release page.
3. integration in the travis workflow.
The conda side is also no yet ready, but this is the part is easier for me:
1. create a windows py37-testing package
2. update the conda-forge freecad-feedstock
3. fork the updated conda-forge freecad-feedstock and do some modifications to upload to freecad/label/dev
sgrogan
Postby sgrogan » Wed Mar 06, 2019 8:19 pm
You are awesome :D
I think we need yorik to give you the proper rights. In the interim if you upload to a release on your github I can copy it over.
If python is available, from the bin directory something like this should work (untested)
import FreeCAD
M=FreeCAD.Version()[1]
m=FreeCAD.Version()[2]
print("FreeCAD_0." + M + "-" + m +"-OSX-x86_64-Qt5-Py3.dmg")
looo
Postby looo » Wed Mar 06, 2019 8:43 pm
hmm, this is not yet working:
>>> sys.path.append(os.path.join(os.environ["CONDA_PREFIX"], "lib"))
>>> import FreeCAD
Segmentation fault: 11
sgrogan
Postby sgrogan » Wed Mar 06, 2019 8:55 pm
On Windows I think it woud be
not "lib" but "Library/bin"
Edit:
conda activate FreeCAD-dev3
python
import os
import sys
sys.path.append(os.path.join(os.environ["CONDA_PREFIX"], "Library/bin"))
import FreeCAD
Result: FreeCAD_0.18-16033 (Git)-OSX-x86_64-Qt5-Py3.dmg
EDIT2: For Kunda1, with deference to blacey, replace "-" with "."?
python
import os
import sys
import FreeCAD
print("FreeCAD_0." + M + "." + m +"-OSX-x86_64-Qt5-Py3.dmg")
Result: FreeCAD_0.18.16065 (Git)-OSX-x86_64-Qt5-Py3.dmg
We should probably parse out the (Git)
If we agree I will modify my win scripts to conform. ...arch-extra packaging info?
Postby Kunda1 » Thu Mar 07, 2019 12:00 am
@sgrogan <hat tip>
issue #3707
looo
Postby looo » Thu Mar 07, 2019 9:54 am
sgrogan wrote: On Windows I think it woud be
Importing FreeCAD from python doesn't work for osx and conda-packages. I don't know the reason for the crash, but I experienced similar crashes also with netgen and we solved it by not linking to python. Somehow conda-packages should have static links to python. (This should give a better performance...) For now I will ignore this crash and use this workaround:
https://github.com/looooo/FreeCAD-AppIm ... version.py
looo
Postby looo » Sat Mar 09, 2019 5:57 am
there is one test failing for osx:
TestPathApp (unittest.loader._FailedTest) ... ERROR
triplus
Postby triplus » Sun Mar 10, 2019 10:09 pm
@sgrogan @triplus
If you created that file locally, sorry i can't help, @sgrogan has such access, for uploading the packages. Once we will figure out on how to create a .dmg file on Travis. Then basically the same procedure, as we use for AppImage, can be used.
