steel structure joint, end plate
I did do a enplate of a steel structure joint with FreeCAD FEM and volume elements and nonlinear material. Attached the pics and the file ... cheers bernd
Re: steel structure joint, end plate
We had a disscussion about calculation of an enplate of steel beam cantilever which ist with bolts at work. The beam on the plate is a is a IPE 200. The plat itself is 30 mm thick. I just said let's do it with volume elements and nonlinear in FreeCAD.
The problem:
The yield point is 235 N/mm2, max sigma should be 223 N/mm2 according national standard, but it is impossible. If the steel starts to yield by 235 the max sigma is above 235. The picture shows any sigma above 240 N/mm2
How about the fixes. Is the fix wron and it should be on top of the plate for the tension bolt hole and on bottom of the plate for the pressure bolt hole.
cheers bernd
The problem:
cheers bernd
is the mesh added to the model. when opening the model the GMSH mesh was empty
- endplate.PNG (44.35 KiB) Viewed 4037 times
mesh is cleared, because it is huge. Double click on gmsh mehs object and recreate it.
btw, nice FreeCAD colour! How to get them?
Bernd, the Von Mises stress should not be above the values defined in the non-linear material object. But as I demonstrated in my knee joint analysis (https://forum.freecadweb.org/viewtopic.php?f=24&t=27431, the nodal values output to FRD are extrapolated from Gauss points and are not necessarily in line with the input values. You can only really rely on the Gauss point values in the DAT file. They will be perfectly in line with the values entered in the non-linear material object.bernd wrote: ↑Fri Nov 02, 2018 4:21 pm We had a disscussion about calculation of an enplate of steel beam cantilever which ist with bolts at work. The beam on the plate is a is a IPE 200. The plat itself is 30 mm thick. I just said let's do it with volume elements and nonlinear in FreeCAD.
The problem:
cheers bernd
Could you also attach a picture of the structure or the 3D model?
I am curious if you have included the bolt preload and how you handled it.
"It is a poor workman who blames his tools..."
Also, as explained in the same analysis, stress itself is a questionable indicator for failure. Local stress concentration on a sharp corner can in theory be infinite, while the structural detail is perfectly ok. What matters in statically loaded details is ductility (full plasticification of the detail - full yielding of the detail without the equivalent plastic strain coming close to the rupture value). This is recognised in design codes by allowing average stresses rather than stress concentrations to govern static design.
I ran your example. It took 20 minutes to run. :shock: The output object reports a maximum von Mises stress of 292MPa and a maximum equivalent plastic strain (PEEQ) of 0.0091. Clearly these are not consistent with your input values, where at a PEEQ of 0.2 the stress should be 240 MPa. This is because of the extrapolation of stress and strain values to the nodes.
The DAT file is too big to load into my spreadsheet tool, but I am pretty sure that a bit of Python wizardry will show that the von Mises stress in the Gauss (integration) points (to be calculated from the formula below) is perfectly in line with the PEEQ (saved to file) in the same point.
