The main problem that I have is that since I'm just starting I make many mistakes. Also I do a lot of trial and error so I end up spending some time opening and closing Freecad. I know some things can be tested from the console but some others can not.
A little off topic, it would be great if the console would have command history.
Anyhow, I'll give you an example to see what I was doing:
In the Mod directory I have created a BoatDesign directory.
Inside that directory I have two files: BoatDesign.py and InitGui.py
InitGui.py
class BoatWorkbench (Workbench):
MenuText = "Boat Design"
def Initialize(self):
import BoatDesign # assuming Scripts.py is your module
list = ["LoadHull","AddKeel","CalcDispl"] # That list must contain command names, that can be defined in BoatDesign.py
self.appendToolbar("Boat Design",list)
Gui.addWorkbench(BoatWorkbench())
BoatDesign.py
import FreeCAD as App
import FreeCADGui as Gui
import Part
import FreeCAD.Base as Base
class LoadHull:
def Activated(self):
'''Loads a hull in any fo the formats supported by FreeCAD'''
if App.ActiveDocument is None:
App.Console.PrintMessage('Creating Document')
App.newDocument("Boat")
App.ActiveDocument=App.getDocument("Boat")
Gui.ActiveDocument=Gui.getDocument("Boat")
App.Console.PrintMessage('Select hull file')
Gui.runCommand("Std_Import")
Gui.runCommand("Std_FitAll")
hull = App.ActiveDocument.Objects[0]
hull.Label='Hull'
def GetResources(self):
return {'Pixmap' : 'path_to_an_icon/myicon.png', 'MenuText': 'Load Hull', 'ToolTip': 'Load a hull for the boat'}
Ok, that works but originally I have written App.activeDocument, wrong case. This is just an example, but the reload method did not work this time. What I did was:
import BoatDesign
reload(BoatDesign)
no errors but when I call the function again the syntax error is still there.
