Problems with DetailView (False Dimension)
kbwbe
Postby kbwbe » Mon Nov 05, 2018 12:02 pm
have problems with a false dimension within a detailview.
Dimension 182,74mm in detailview is 224,74mm in mainview. (224,74 is the correct one).
File is attached. Do i something wrong or is this a bug ?
I am on:
OS: Linux Mint 18.3 Sylvia
Version: 0.17.13522 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.12
Thank you for any help.
Drawing.fcstd
(179.41 KiB) Downloaded 22 times
KBWBE
latest release: v0.4.47f, installable via FreeCAD's addon manager
wandererfan
Re: Problems with DetailView (False Dimension)
Postby wandererfan » Mon Nov 05, 2018 3:16 pm
Looks like a bug to me. I'll look deeper when I get home.
wandererfan
Postby wandererfan » Tue Nov 06, 2018 7:42 pm
Definitely a bug, but not the bug it appears to be.
Bottom is inverted (as it should be), but DetailView is right side up. The Dimension in DetailView is at the other end of the piece compared to the the Dimension in Bottom. So the 2 points of the Dimension in the DetailView are not the same points as the Dimension in Bottom.
DetailView will have to be modified to be aware when the Source view is part of a ProjectionGroup and is shown inverted.
kbwbe
Postby kbwbe » Tue Nov 06, 2018 8:18 pm
Thank you for your work, Chris!
KBWBE
wandererfan
Postby wandererfan » Sat Nov 10, 2018 1:14 pm
ping
PR1786 submitted for this issue.
kbwbe
Postby kbwbe » Sat Nov 10, 2018 1:51 pm
Great ! Thank you very much.
KBWBE
