0.17 & Mac Mojave total crash
pipo
Postby pipo » Tue Nov 06, 2018 8:32 pm
I have installed mojave, the lastes MAC OS release, last week on my mac book pro from mid 2014.
At first i had experienced the freezing by launching freecad as it it described here in the forum and also in youtube.
It's not very nice, .... but well..... okay.
But now i have experienced a total crash of my mac when i use the alignment feature (Black Screen). This total crash is reproducible, until now it always came back when i try to use the alignment feature.
So now i'm really desperate and frustrated because i can not finish my work and start the 3d printing. Also i don't know were this problem comes from.
Has someone experienced some same behavior?
I'm happy for any help!!!!
In Regards
Philipp
My System:
MacBook Pro (Retina, 13', Mitte 2014)
2,8 GHz Intel Core i5
16 GB 1600 MHz DDR3
My freecad
OS: Mac OS X
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
Locale: English/Germany (en_DE)
Re: 0.17 & Mac Mojave total crash
Postby chrisb » Tue Nov 06, 2018 9:28 pm
I'm afraid it will not help, but you should try the latest 0.18 release.
If that doesn't help I would offer that you upload your model, I apply the feature (you will have to explain what you mean with "alignment feature") and the you try to continue your work with the updated model.
leonardshelby
Postby leonardshelby » Tue Nov 06, 2018 11:48 pm
For the freezing on MacOS Mojave I have found a hack that seems to work for others as well: start freecad inside terminal.
To do so open a new terminal window (cmd-space, type terminal, enter). then type:
/Applications/FreeCAD.app/Contents/MacOS/FreeCAD
Postby chrisb » Tue Nov 06, 2018 11:53 pm
Thanks for reporting. Can anyone else using MacOS Mojave confirm this? I would like to add it to the known issues list.
pipo
Postby pipo » Wed Nov 07, 2018 4:59 am
@chrisb: first thanks for your offer to help and do the "alignment work" for me. Unfortunately it would be a lot of work to do. Therefore i will try the versiom 0.18 first.
With alignment feature or function I mean the split screen what is used to shoos points on two objects to align the objects. You can find this feature under edit directly below placement.
I believe that feecad has issues under Mohave to create this split screen and create a system crash.
Yes it would be really great if someone can confirm this! Maybe i have an other issue here what i could solve myself.
easyw-fc
Postby easyw-fc » Wed Nov 07, 2018 6:38 am
In Regards
Philipp
My System:
16 GB 1600 MHz DDR3
Hi Philipp
to align your objects you may consider to install manipulator WB and use the Aligner tool.
Maurice
pipo
Postby pipo » Wed Nov 07, 2018 9:39 pm
HI,
@easyw-fc: I guess i need some practice with that tool but the first trail showed no crash, only moving parts! Very nice! It looks like a very nice tool.
Thanks!!!!!
In Regards
Philipp
Darcad
Postby Darcad » Thu Nov 08, 2018 6:47 am
Hi all,
I have also a crash but only when i work on a project and i need to open a new document or a second project. My mac restart with a issue message. I tried to start Freecad with terminal. And a red message appear.(picture)
Have someone and idea what i can do to resolve that?
Thank you in advance.
Capture d’écran 2018-11-08 à 07.31.14.png (28.68 KiB) Viewed 1695 times
OS: macOS 10.14
Ws of OS: 64-bit
Ws of FreeCAD: 64-bit
V: 0.18.14976 (Git)
B T: Release
Brc (HEAD detached at e79a19828)
Hash: e79a19828e2e92269ff96110dfeadaa245ad17c2
Python v: 2.7.15
Qt v: 5.11.2
Coin v: 4.0.0a
OCC v: 7.2.0
(fr_CH)
Postby chrisb » Thu Nov 08, 2018 7:22 am
You are using the additional Animation workbench, which I don't use, so the following is a bit guesswork:
- Animation workbench seems to need matplotlib, which you have to install separately.
- brew install matplotlib should install the library.
If you don't need this workbench, uninstall it.
pablogil
Postby pablogil » Tue Nov 13, 2018 11:04 pm
It also happens to me... BTW, if starting it up from Terminal it works like a charm.
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
