Travis-CI, mac, clang and permanent failure.
PrzemoF
Postby PrzemoF » Thu Nov 15, 2018 1:56 pm
All Travis-CImac/clang builds fail for the last month. A quick check shows error:
The job exceeded the maximum log length, and has been terminated.
I checked random 6 builds and they all failed for the same reason. If we can't make the clang/mac build more quiet or travis-ci can't give us more space for log I propose to switch off those mac builds.
Re: Travis-CI, mac, clang and permanent failure.
Postby Kunda1 » Thu Nov 15, 2018 5:04 pm
we can also consider purchasing (with some of the funds from bountysource) an account on TravisCI so that we can get longer time-limits
PrzemoF
Postby PrzemoF » Thu Nov 15, 2018 8:21 pm
Time is not the problem anymore - FreeCAD got that for free. Log length is the problem.
Edit: I asked them for advice.
sgrogan
Postby sgrogan » Thu Nov 15, 2018 8:30 pm
The builds have been failing for some time. There is a packaging problem. Travis updated the version of OSX they use which Peterl94 said is the problem. It looks like now there is a problem with the cache, Travis still seems to be building dependencies when it fails.
Peter said he will not have time to fix this for a while because of dayjob commitments. I think disabling the osx builds temporarily is a good idea, right now we are just wasting resources for no gain.
Postby Kunda1 » Thu Nov 15, 2018 9:52 pm
Thanks for the explanation.
That's a shame.
PrzemoF
Postby PrzemoF » Thu Nov 15, 2018 9:55 pm
I'm having conversation with travis-ci - they made the same mistake (log --> time). I hope we can get it fixed :D If sgrogan is right it will be just a step to fix the other problem.
PrzemoF
Postby PrzemoF » Thu Nov 15, 2018 10:21 pm
Travis support is as always top class!
1) You can pipe the verbose output of your command to a file and display the last 500-1000 lines on build failure, e.g.
script:
  - command ... > cmd_output.txt
after_failure:
  - tail -n 500 cmd_output.txt
2) If you cannot see the error in the last 500-1000 lines of logs, you could upload your entire log file to sites like chunk.io or transfer.sh like this:
script:
after_failure:
  - curl -T cmd_output.txt chunk.io
The curl command would give you back a chunk.io URL (e.g.http://chunk.io/f/1edae590c82d46deb930b4237828d809) where you can access your whole log file. Ensure you have no sensitive data in your build logs if you use this method. This is probably the best method if you need to preserve your entire log, but if you only really need to see the errors, method 1 is better.
3) Lastly, if you do have sensitive data in the logs, you can upload your command's log output file to S3 using your S3 credentials and our artifacts addon. You can see the documentation on how to do this here: http://docs.travis-ci.com/user/uploading-artifacts/.
Any volunteers to test it? I think it could be handy for all our builds - no need to scroll through tons of logs after a failure. We don't have any sensitive data in the logs, nor we need to keep it, so solution No. 1 is my pick.
Postby Kunda1 » Thu Nov 15, 2018 11:04 pm
1st solution is effective but 2nd solution will actually help us discover any warnings in the builds...so I vote for solution no.2 in the long run
PrzemoF
Postby PrzemoF » Fri Nov 16, 2018 1:04 pm
@Kunda1: do you have any service in mind that could take our logs? chunk.io is invite only now.
PrzemoF
Postby PrzemoF » Fri Nov 16, 2018 1:08 pm
