Travis-CI, mac, clang and permanent failure.
Re: Travis-CI, mac, clang and permanent failure.
Postby Kunda1 » Fri Nov 16, 2018 2:39 pm
PrzemoF wrote:
Fri Nov 16, 2018 1:04 pm
@Kunda1: do you have any service in mind that could take our logs? chunk.io is invite only now.
The service is now invite-only. Please send an email at hello@chunk.io if you'd like to get access to the service.
yorik wrote:
hey @yorik would you be able to send a message as a core-dev of FreeCAD asking to be invited ?
PrzemoF
Postby PrzemoF » Fri Nov 16, 2018 3:18 pm
My fix failed. Someone with mac knowledge is needed to fix it.
yorik
Site Admin
Postby yorik » Fri Nov 16, 2018 7:23 pm
Done!
PrzemoF
Postby PrzemoF » Wed Nov 28, 2018 2:44 pm
I'm trying to get it fixed, but there is a cache error [1]. That this function: [2]
[1] https://travis-ci.org/FreeCAD/FreeCAD/j ... 84288#L204
[2] https://github.com/FreeCAD/FreeCAD-port ... rs.sh#L203
yorik
Site Admin
Postby yorik » Thu Nov 29, 2018 1:24 pm
Okay I got a chunk.io access:
Congratulations! You can now access all chunk.io functionalities using the -u flag of cURL, e.g.: curl -u FreeCAD:password -T file chunk.io
Anyone else who needs the password please PM me
PrzemoF
Postby PrzemoF » Mon Dec 03, 2018 2:34 pm
Anyone knows why this is failing? [1]. My macos knowledge is limited to the fact that it's related to unix somehow.
[1] https://travis-ci.org/FreeCAD/FreeCAD/jobs/461836424
tom
Postby tom » Mon Dec 03, 2018 9:29 pm
IMHO now it is not an OSX specific problem, but it is Travis related. Travis does not see any output since you are redirecting all stdout into a log file. After 15 minutes of silence Travis assumes that the build process is stuck in an endless loop and thus it kills the build. I have no idea how to solve this. Either we have output on stdout/stderr and Travis fails because of reaching the 1 million lines limit or we have no output and Travis fails, because the build is too silent. We would need some kind of heartbeat for Travis.
tom
Postby tom » Mon Dec 03, 2018 9:49 pm
Perhaps that will help:
Instead of
CMD >> build_output.txt
try this
CMD | tee -a build_output.txt | sed "s/^.*//" | tr '\n' '.'
Basically, this will print a dot to stdout for each line of the build_output.txt. So, instead of getting over 1 million log lines we will see only 1 million dots on one line while the original output is still being redirected into build_output.txt.
PrzemoF
Postby PrzemoF » Mon Dec 03, 2018 10:04 pm
Thanks!! That makes sense - I'll try and report back.
Edit: I used time stamp - if that fails I'll got for dots or a time stamp once in a while
https://travis-ci.org/FreeCAD/FreeCAD/jobs/463054982
sgrogan
Postby sgrogan » Mon Dec 03, 2018 11:05 pm
Me too ;)
I think the root cause is here: https://forum.freecadweb.org/viewtopic.php?f=4&t=31694
Related: https://docs.travis-ci.com/user/reference/osx/
I think Peter might be lurking: https://www.somsubhra.com/github-releas ... ry=freecad
"fight the good fight"
