compile with py3 and Qt5 on Debian Stretch
kkremitzki
Re: compile with py3 and Qt5 on Debian Stretch
Postby kkremitzki » Tue Nov 20, 2018 10:46 pm
bernd wrote:
Tue Nov 20, 2018 10:42 pm
I havae problems with Qt5 on Debian Buster ...
Can you try adding -DPYTHON_CONFIG_SUFFIX="-python2.7.x86_64-linux-gnu" to your cmake flags?
user1234
Postby user1234 » Tue Nov 20, 2018 10:49 pm
Hello!
Try
I do not know anymore who tells me that trick. But the VTK is mad on Debian testing. The new CMake do not like that.
Greetings
user
edit, as always to late ....
bernd
Postby bernd » Tue Nov 20, 2018 11:20 pm
the shiboken and pyside errors are gone ... :)
still the qt5x11extras are somehow missing ...
CMake Error at src/Gui/CMakeLists.txt:110 (find_package):
  By not providing "FindQt5X11Extras.cmake" in CMAKE_MODULE_PATH this project
  has asked CMake to find a package configuration file provided by
  "Qt5X11Extras", but CMake did not find one.
  Could not find a package configuration file provided by "Qt5X11Extras" with
  any of the following names:
    Qt5X11ExtrasConfig.cmake
    qt5x11extras-config.cmake
  Add the installation prefix of "Qt5X11Extras" to CMAKE_PREFIX_PATH or set
  "Qt5X11Extras_DIR" to a directory containing one of the above files.  If
  "Qt5X11Extras" provides a separate development package or SDK, be sure it
  has been installed.
-- Configuring incomplete, errors occurred!
but
$ dpkg -l | grep  qt5x11extras
ii  libqt5x11extras5:amd64                 5.11.2-2                     amd64        Qt 5 X11 extras
kkremitzki
Postby kkremitzki » Wed Nov 21, 2018 12:27 am
Try grabbing the libqt5x11extras5-dev package.
Edit: The apt-file tool is good for this:
$ apt-file search Qt5X11ExtrasConfig.cmake
libqt5x11extras5-dev: /usr/lib/x86_64-linux-gnu/cmake/Qt5X11Extras/Qt5X11ExtrasConfig.cmake
bernd
Postby bernd » Wed Nov 21, 2018 5:49 am
:D 8-)
bernd
Postby bernd » Wed Nov 21, 2018 9:48 pm
first step is done. It compiles on Debian Buster with Qt5 ...
https://github.com/berndhahnebach/FreeC ... Qt5_Py2.sh
next step will be Py3 afterwards I decide it I give Stretch a try in compiling FreeCAD Qt5Py3 or if I give Buster a try on my Computer ... :geek:
kkremitzki
Postby kkremitzki » Wed Nov 21, 2018 10:02 pm
The release of Buster is coming up so switching to it in advance is not such a bad idea.
bernd
Postby bernd » Thu Nov 22, 2018 9:36 am
FreeCAD Qt5 runs on Buster. Next step is Python 3.
kkremitzki wrote:
Mon Nov 19, 2018 8:02 pm
Right now all you need to build Qt5 + Py3 on Debian Buster is a python3-pivy package. You can refer to my package for that here: https://salsa.debian.org/kkremitzki-guest/pivy
The pivy from your repo are just Python files. What do I need to do with them?
How do I tell cmake that it trys to compile against Python3 and it finds my brand new pivy?
Bernd
kkremitzki
Postby kkremitzki » Thu Nov 22, 2018 4:22 pm
Bernd
It's the debian folder that contains the magic, if you're in the top-level folder you should be able to run:
git archive upstream | gzip > ../pivy_0.6.4.orig.tar.gz
dpkg-buildpackage -us -uc
to produce all the .deb files associated with that package.
abdullah
Postby abdullah » Sun Nov 25, 2018 6:02 am
EDIT: I really replied to something old. You might delete this post.
