compile with py3 and Qt5 on Debian Stretch
bernd
Re: compile with py3 and Qt5 on Debian Stretch
Postby bernd » Wed Dec 19, 2018 10:03 pm
https://forum.freecadweb.org/viewtopic. ... 90#p274393 helped myself ...
eventually ...
cmake                                                       \
-DCMAKE_INSTALL_PREFIX:PATH=/opt/local/FreeCAD-0.18         \
-DBUILD_QT5=ON                                              \
-DCMAKE_BUILD_TYPE="DEBUG"                                  \
-DFREECAD_BUILD_DEBIAN=ON                                   \
-DOCC_INCLUDE_DIR="/usr/include/occt"                       \
-DFREECAD_USE_OCCT_VARIANT="Official"                       \
-DPYTHON_BASENAME=".cpython-37m-x86_64-linux-gnu"           \
-DPYTHON_CONFIG_SUFFIX=".cpython-37m-x86_64-linux-gnu"      \
-DPYTHON_EXECUTABLE="/usr/bin/python3.7"                    \
../freecad
or the whole build script for a Debian Buster scratch install ... https://github.com/berndhahnebach/FreeC ... Qt5_Py3.sh
triplus
Postby triplus » Thu Dec 20, 2018 5:32 pm
wmayer wrote:
Fri Nov 30, 2018 8:55 am
bernd wrote:
Thu Nov 29, 2018 9:30 pm
I'm not really able to solve this Werner ...
kkremitzki wrote:
Tue Nov 20, 2018 10:46 pm
bernd wrote:
Tue Nov 20, 2018 10:42 pm
I havae problems with Qt5 on Debian Buster ...
Can you try adding -DPYTHON_CONFIG_SUFFIX="-python2.7.x86_64-linux-gnu" to your cmake flags?
This does not work on Python3. Means if I use 3.6 instead of 2.7 the errors do not vanish like for 2.7
Which errors?
Note, that with recent commits from Wednesday it should now work that CMake determines itself the variable PYTHON_CONFIG_SUFFIX. Therefore it reads in Shiboken2Config.cmake which internally sets PYTHON_CONFIG_SUFFIX to an inappropriate value. Afterwards from the given path of the config file CMake searches for further config files which has .cpython<PYTHON_VERSION> in its name and if it has found one it determines the correct value of PYTHON_CONFIG_SUFFIX and then re-reads Shiboken2Config.cmake.
You can check if the procedure succeeded by looking at the CMake output. You should find a line of the form: PYTHON_CONFIG_SUFFIX: ...
git commit 1dded002ca
I can confirm setting (Ubuntu 16.04):
-DBUILD_QT5=1 -DPYTHON_EXECUTABLE="/usr/bin/python3"
Should suffice (CMake does the rest).
bernd
Postby bernd » Sun Dec 23, 2018 3:31 am
you are right, it is much simpler. On Debian Buster I need with all packages from Debian accept pivy for Py3:
cmake  -DBUILD_QT5=1  -DPYTHON_EXECUTABLE="/usr/bin/python3"  -DOCCT_CMAKE_FALLBACK=True   ../freecad
reox
Postby reox » Sat Dec 29, 2018 11:24 am
I read through this thread now and I'm wondering if it would be possible to create nightly builds for debian testing or unstable with the current set of packaging?
I have pbuilder setup for some packages of mine and could try to integrate a nightly build there.
Or is there already something like this? (not the ubuntu ppa)
NormandC
Postby NormandC » Sat Dec 29, 2018 10:30 pm
The issue is: where to host them? A properly configured debian repository is needed. The current Releases page on GitHub isn't suited for this.
reox
Postby reox » Sun Dec 30, 2018 12:56 pm
I use reprepro (https://packages.debian.org/stretch/reprepro) for this.
I could build and host them on my machine, but that depends on the traffic.
Isnt it possible to build also debian packages on build.opensuse.org? In this case you could simply build it there. It looks like the appimages are already build there.
Site Admin
Postby wmayer » Sun Dec 30, 2018 1:24 pm
Basically it doesn't matter where to host the files. The only important thing is to provide the required directory structure and files. I remember that several years ago someone succeeded to have the repository on dropbox.
reox
Postby reox » Sat Jan 05, 2019 7:21 pm
Dugh... :oops: I remembered just now, that I already wrote a script to build the latest freecad version using the stuff from the ppa: https://gist.github.com/reox/522922a1a6 ... edd484f48f
better look on your own gist :lol:
I'm currently testing this on my pbuilder machine
edit: But this does not build fully...
make[1]: Leaving directory '/home/vmmanage/packages/FreeCAD/obj-x86_64-linux-gnu'
   dh_install -O--buildsystem=cmake -O--parallel
dh_install: Compatibility levels before 9 are deprecated (level 7 in use)
dh_install: Cannot find (any matches for) "usr/lib/freecad-daily/lib" (tried in ., debian/tmp)
dh_install: freecad-daily missing files: usr/lib/freecad-daily/lib
dh_install: missing files, aborting
make: *** [debian/rules:8: binary] Error 25
dpkg-buildpackage: error: fakeroot debian/rules binary subprocess returned exit status 2
$ ls -al debian/freecad-daily/usr/lib/freecad-daily/
total 16
drwxr-xr-x  4 root root 4096 Jan  6 00:28 .
drwxr-xr-x  3 root root 4096 Jan  6 00:28 ..
drwxr-xr-x  2 root root 4096 Jan  6 00:27 bin
drwxr-xr-x 35 root root 4096 Jan  6 00:27 Mod
fandres
Postby fandres » Thu Aug 29, 2019 2:57 am
I have also not managed to compile freecad in a debited cluster :(. I have the following errors:
CMake Error at cMake/FindOpenCasCade.cmake:95 (file):
file STRINGS file "/usr/include/occt/Standard_Version.hxx" cannot be read.
CMakeLists.txt:668 (find_package)
CMake Error at cMake/FindOpenCasCade.cmake:98 (string):
string sub-command REGEX, mode MATCH needs at least 5 arguments total to
command.
CMake Error at cMake/FindOpenCasCade.cmake:99 (file):
CMake Error at cMake/FindOpenCasCade.cmake:102 (string):
command.
CMake Error at cMake/FindOpenCasCade.cmake:103 (file):
CMake Error at cMake/FindOpenCasCade.cmake:106 (string):
command.
fandres
Postby fandres » Thu Aug 29, 2019 4:02 am
I have already compiled it, my directories were dirty.
