cfMesh install problem
Moderator: oliveroxtoby
julieng
Re: cfMesh install problem
Postby julieng » Tue Nov 27, 2018 9:33 pm
Thank you for your answer. I re-install cfdof by removing the module and install it again.
I re-install blue-cfd core, cfmesh and hisa. The preference page has not been closed during installation.
The same message occurs :
cfmesh not found
hisa not found
Best regards
Julien
log.Allwmake_hisa.log
log file hisa
(51.51 KiB) Downloaded 7 times
log - Allwmake2.log
log file cfmesh
(830 Bytes) Downloaded 10 times
oliveroxtoby
Postby oliveroxtoby » Wed Nov 28, 2018 6:19 am
cfmesh not found
hisa not found
Best regards
Julien
Something seems to be interrupting the build processes before they are complete. Please could you look at the bug reporting guidelines at https://forum.freecadweb.org/viewtopic.php?f=37&t=27055 and provide all the output from the report window. Hopefully there will be some hint there as to why they are being cut off.
julieng
Postby julieng » Wed Nov 28, 2018 8:10 pm
I uninstall and re-install CFDOF again according to your comments.
I have again the same error message.
Nothing in the script window appears during the installation
Best regards
log hisa
(21.72 KiB) Downloaded 7 times
log.Allwmake_cfmesh.log
log cfmesh
(830 Bytes) Downloaded 7 times
oliveroxtoby
Postby oliveroxtoby » Thu Nov 29, 2018 6:35 am
What about the Report View (visible in the bottom left on the attached screen shot). You should at least see the output of the build process there. If not, please make sure you have followed the instructions in the post linked above, and copy its entire contents so we can see if there is any error which interrupted the process.
Screenshot from 2018-11-29 08-30-49.png (259.29 KiB) Viewed 265 times
julieng
Postby julieng » Sat Dec 01, 2018 8:25 am
I do again the whole installation and now, I have only HiSA not found!
I have the Following message in the preference window:
Downloading blueCFD-Core, please wait...
blueCFD-Core downloaded to C:\Users\julien\Downloads\blueCFD-Core-2017-2-win64-setup.exe
blueCFD-Core installer launched - please complete the installation
Downloading cfMesh, please wait...
Extracting cfMesh...
Download completed
Building cfMesh. Lengthy process - please wait...
Log file: C:\Program Files\blueCFD-Core-2017\OpenFOAM-5.x\..\ofuser-of5\log.Allwmake
Downloading HiSA, please wait...
Extracting HiSA...
Download completed
Building HiSA. Please wait...
Log file: C:\Program Files\blueCFD-Core-2017\OpenFOAM-5.x\..\ofuser-of5/hisa-master/log.Allwmake
Checking dependencies...
HiSA not found
Best regards
log.Allwmake.hisa.log
log hisa
(48.69 KiB) Downloaded 10 times
log.Allwmake.log
log cfmesh
(830 Bytes) Downloaded 6 times
oliveroxtoby
Postby oliveroxtoby » Sun Dec 02, 2018 7:57 pm
Download completed
Extracting HiSA...
Download completed
HiSA not found
Best regards
Are you absolutely sure you are waiting long enough for the build to complete? You should see the message "Install completed" some time after "Building cfMesh" and "Building HiSA". I do not see this in your output. You should not have to reinstall everything. Just go to preferences and re-try the "Install HiSA" option, and wait as long as necessary for "Install completed" to come up.
There is really nothing more I can say without the full output of the Report view (not the build logs). Please could you look at the bug reporting guidelines https://forum.freecadweb.org/viewtopic.php?f=37&t=27055
julieng
Postby julieng » Tue Dec 04, 2018 12:12 pm
Thank you for your help, you were right I didn't wait enough time! Sorry
Now everything works
Best regards
