[conda] compile calculix for osx and windows
looo
Postby looo » Fri Nov 23, 2018 9:47 am
Has anybody successfully compiled calculix for osx? I am wondering if it makes sense to try this [1]. Also I am trying to compile calculix for windows with the mingw-toolchain. I think @easyw was successful on windows. Maybe we can transfer the instruction into a build-instruction for conda.
I guess in theory it should be possible to support all 3 major platforms, but some help would be nice! [2]
easyw-fc wrote:
[1] https://travis-ci.org/conda-forge/stage ... tification
[2] https://github.com/conda-forge/staged-recipes/pull/6827
looo
Re: [conda] compile calculix for osx and windows
Postby looo » Fri Nov 23, 2018 10:11 am
For windows it looks like it is a bit more difficult. spooles and arpack are not yet available:
https://github.com/conda-forge/spooles- ... a.yaml#L17
https://github.com/conda-forge/arpack-feedstock/pull/22
So I guess this will need some time until we can compile calculix with flang and clang...
bernd
Postby bernd » Fri Nov 23, 2018 1:46 pm
peterl94
Postby peterl94 » Sun Nov 25, 2018 12:30 am
I've always just used the homebrew package built using this formula: https://github.com/brewsci/homebrew-sci ... lix-ccx.rb
looo
Postby looo » Sun Nov 25, 2018 3:13 pm
Thanks for the instructions. I hope osx won't need too much iterations to get the builds succeed. For Windows arpack is now available build with the mingw-toolchain. So I will try to use the same toolchain for spooles and calculuix too.
UR_
Postby UR_ » Sun Nov 25, 2018 3:39 pm
ccx is a really sensible piece of software, showing it's weak spots only after doing tons of tests.
So let's speak this guy ("kwip" from mecway forum):
I did some research finding other projects having issues with ARPack which is kind of EOL. ocatve, scilab were forking their own implementation. There is some effort of consolidation, namely arpack-ng. I'll try to build CCX against this arpack version. Maybe we are lucky. I'll report back when I've put the required dependencies together.
http://mecway.com/forum/discussion/comm ... mment_2511
Results can be found here:
https://github.com/ddfem/ccx_mingw64/commits/master
Especially if it comes to non static calculations, this build is really appreciated.
looo
Postby looo » Sun Nov 25, 2018 6:00 pm
actually the arpack-package on conda-forge uses sources from arpack-ng [1]. There is also another arpack (arpackpp [2]). Do you know for which part ccx uses arpack and for which it uses spooles?
[1] https://github.com/conda-forge/arpack-feedstock
[2] https://github.com/conda-forge/arpackpp-feedstock
UR_
Postby UR_ » Sun Nov 25, 2018 6:35 pm
For an overview please refer to docs
http://www.dhondt.de/ccx_2.14.pdf
see page 570 chapter 9.6:
9.6 Filling and solving the set of equations, storing the results
In this section a distinction is made between the types of analysis and the solver
used:
• for linear static calculations with SPOOLES or the iterative solver the appropriate routine is prespooles.c
• for nonlinear static or dynamic calculations (which implies the use of SPOOLES or the iterative solver) routine nonlingeo.c is called. This includes all thermal calculations.
• for frequency analysis without cyclic symmetry routine arpack.c is called.9.6 Filling and solving the set of equations, storing the results 571
• for a frequency analysis with cyclic symmetry conditions the appropriate routine is arpackcs.c
• for a buckling analysis arpackbu.c is called
• for linear dynamic calculations (i.e. modal dynamic analysis) the routine is dyna.c
• finally, for steady state dynamics calculations the routine is steadystate.c
Postby Kunda1 » Mon Nov 26, 2018 10:53 am
looo
Postby looo » Thu Nov 29, 2018 8:52 pm
I was able to build spooles for windows on my machine. There is still a problem with recursive copying the header files (appveyor):
https://ci.appveyor.com/project/conda-f ... 8069#L1889
If anyone knows a better way to copy header files, please let me know.
