Can’t parallel the solver
Moderator: oliveroxtoby
Maxim Gryaznov
Postby Maxim Gryaznov » Tue Dec 11, 2018 3:31 pm
Hi, CfdOF / CFD members!
I want to run simulations on several cores. So, i write in Solver:
Parallel = true
Parallel cores = 4.
Then i press “Write OpenFOAM case”. When it completes, i press “Run Solver”. After about 30 seconds, it exits with an error:
ERROR: Failed to post close command error 1726
ERROR: unable to tear down the job tree. exiting...
— there are the same two lines in log.simpleFoam only.
Status window:
0.0: Checking dependencies...
0.0: OpenFOAM case writer is called
3.8: Write OpenFOAM case is completed
0.2: Starting solver command:
0.2: C:\BLUECF~1\OPENFO~1.X\..\msys64\usr\bin\bash --login -O expand_aliases -c cd "/c/tselli/FreeCAD CFDOF/Cube/case" && ./Allrun
0.3: Solver started
36.3: Simulation exited with error
Report window:
Last lines in Python window:
>>> FreeCAD.getDocument("Cube").getObject("OpenFOAM").Parallel = True
>>> FreeCAD.getDocument("Cube").getObject("OpenFOAM").ParallelCores = 4
report & python.png (201.64 KiB) Viewed 271 times
If i don’t run parallel, it works ok. So, what should i do to run the parallel solver?
P. S. Before FreeCAD/BlueCFD/CfdOF i made parallel simulations in STAR CCM+: 4 cores worked great.
___
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Locale: Russian/RussianFederation (ru_RU)
Last edited by Maxim Gryaznov on Sat Dec 15, 2018 3:37 pm, edited 2 times in total.
✌️ Maxim Gryaznov
thschrader
Re: Can’t parallel the solver
Postby thschrader » Tue Dec 11, 2018 5:14 pm
Hi Maxim,
welcome to the FreeCAD-forum.
Can you post your FreeCAD-file?
It is easier to have a concrete problem than to guess a solution.
Thomas
Maxim Gryaznov
Postby Maxim Gryaznov » Tue Dec 11, 2018 6:14 pm
Thomas
Thanks for your quick response, Thomas!
There is a working directory with FCStd files and cases. Hope, it’s enough:
https://drive.google.com/file/d/1OYLtXi ... sp=sharing
✌️ Maxim Gryaznov
thschrader
Postby thschrader » Wed Dec 12, 2018 11:31 am
Hi Maxim,
I have no problem to run your file. But I get strange results.
When running a laminar case, it "works".
Thomas
Maxim Gryaznov
Postby Maxim Gryaznov » Wed Dec 12, 2018 12:01 pm
Thank you Thomas!
Thomas
It’s strange: i got the second picture with the turbulent case.
Did you make any setups on your computer before running parallel calculations? Maybe i should make something to allow OpenFOAM to make parallel runs?
✌️ Maxim Gryaznov
oliveroxtoby
Postby oliveroxtoby » Wed Dec 12, 2018 1:00 pm
My guess would be that there is a problem with your installation of MPI. Try re-installing blueCFD-Core, and make sure to install the MSMPI library (it is installed by default).
If that doesn't work please take a look at https://forum.freecadweb.org/viewtopic.php?f=37&t=27055 and follow the instrucitons - there may be some output that would give a clue.
Maxim Gryaznov
Postby Maxim Gryaznov » Sat Dec 15, 2018 3:37 pm
Oliveroxtoby!
Sorry for the late reply. I reinstalled blueCFD-Core and MPI: now i have 7.1.12437.25 version. It was in an installation tutorial (http://bluecfd.github.io/Core/UserGuide/). Unfortunately, i have the same error.
✌️ Maxim Gryaznov
oliveroxtoby
Postby oliveroxtoby » Sat Dec 15, 2018 7:56 pm
Apologies - I didn't notice that you had attached a screenshot the first time.
Some googling suggests this is some sort of an issue with MS MPI. I can only suggest you try installing the latest one in place of the version that came with blue CFD - https://docs.microsoft.com/en-us/messag ... rosoft-mpi.
Good luck!
Maxim Gryaznov
Postby Maxim Gryaznov » Sat Dec 15, 2018 9:20 pm
Hey, oliveroxtoby!
No, that’s my bad: i uploaded the screenshot after your message — i didn’t say, that i updated my post. I’m sorry.
I tried three versions:
1. 8.1.many-numbers-after when i created this topic
2. 7.1.12437.25 after your suggestion about reinstallation blue-core
3. 10.0.12498.5 after your last message.
Unfortunately, they didn’t solve my issue.
✌️ Maxim Gryaznov
thschrader
Postby thschrader » Sun Dec 16, 2018 10:32 am
There is a video from Bruno Santos how to install bluecfd.
Goto 2:30. The MS-MPI installer given with bluecfd should overwrite an existing MPI.
But sometimes this does not work (on my machine). So be sure to uninstall all
existing MPI (reboot system) before installing bluecfd.
About computing forces in paraview please see pics.
https://www.youtube.com/watch?v=nl7er2t-TnU
