Changing of the transparency parameter on Radeon GPU problem
mnv
Postby mnv » Thu Dec 13, 2018 5:47 am
Has anyone tried to change the transparency parameter on last FreeCAD build?
Unfortunately, i got some problems with that on my PC with Radeon GPU.
This problem occured only on FreeCAD builds with Qt5.
Link on tracker: https://www.freecadweb.org/tracker/view.php?id=3725
FreeCAD About Info:
Version: 0.18.15299 (Git)
Hash: 5217b245b4f98cf1e3f63ecfe20e379fe4923d80
Python version: 3.6.6
Qt version: 5.6.2
Re: Changing of the transparency parameter on Radeon GPU problem
Postby chrisb » Thu Dec 13, 2018 8:51 am
Moved to Help forum
Postby chrisb » Thu Dec 13, 2018 8:54 am
Hi mnv, welcome to the forum.
The Radeon cards are known to cause problems. You may try to downgrade the driver: https://forum.freecadweb.org/viewtopic.php?f=3&t=30573.
mnv
Postby mnv » Fri Dec 14, 2018 9:20 am
Unfortunately, this problem is also occurred on old driver version.
I think this problem in porting to Qt5, because old FreeCAD versions and builded by hand FreeCAD version with Qt4 works fine.
Postby Kunda1 » Fri Dec 14, 2018 11:25 am
So essentially it may be an upstream Qt5 issue?
