Honeycomb (fits all bees)
Roland
Postby Roland » Mon Dec 17, 2018 3:59 pm
Dear Forum,
It seems that I finally cracked it. My adjustable honeycomb should fit all bees. (100% parametric)
Honeycomb_FitsAllBees.pdf
(63.37 KiB) Downloaded 390 times
Honeycomb_FitsAllBees.FCStd
(456.12 KiB) Downloaded 87 times
The idea is that basic parameter values can be set in a spreadsheet (like element radius, wall between elements, number of rows and columns).
Although provided here for hexagons as a primary shape, the approach can be useful for circles, and other shapes as well. In this manner pipe bundles for heat exchangers could be designed.
Suggestions for improvement are most welcome.
Greetz
Roland
bitacovir
Re: Honeycomb (fits all bees)
Postby bitacovir » Mon Dec 17, 2018 4:48 pm
Thanks for sharing the file.
If you explain a lite bit about context and applications it would be nice (also for a better feedback).
::bitacovir::
My Blog
Mini Airflow Tunnel Project
Roland
Postby Roland » Mon Dec 17, 2018 5:52 pm
That's a first very good suggestion!
Done
triplus
Postby triplus » Sat Dec 22, 2018 5:13 pm
Did a quick test and it works as advertised.
Thanks for sharing.
Postby Kunda1 » Sun Dec 23, 2018 1:58 pm
Roland, can you edit the first post and add some screenshots, please ?
