Concrete branch ready for testing
bernd
Re: Concrete branch ready for testing
Postby bernd » Thu Apr 04, 2019 8:52 pm
HarryvL wrote:
Thu Apr 04, 2019 7:43 pm
bernd wrote:
Thu Apr 04, 2019 7:12 pm
there you have a normal material object and nog a reinfoced material object.
Yes, but I cannot do anything with that object. Do I still have to use Python to link material objects to the reinforced material object?
https://forum.freecadweb.org/viewtopic. ... 20#p297144
bernd
Postby bernd » Thu Apr 04, 2019 8:53 pm
HarryvL
Postby HarryvL » Fri Apr 05, 2019 3:55 am
added the unit test ... https://github.com/berndhahnebach/FreeC ... 85dc1681f5
:D
bernd
Postby bernd » Mon Apr 08, 2019 12:57 pm
added a task panel and two materials, concrete-harry and reinforcement-harry. We need to replace them but for testing I found this useful :D
Would you give all this femconcrete another try? May be add material from scratch to one of your example file.
HarryvL
Postby HarryvL » Tue Apr 09, 2019 4:23 am
OK will do
HarryvL
Postby HarryvL » Tue Apr 09, 2019 5:23 am
git pull -X https://github.com/bernhahnebach/FreeCAD_bhb femconcrete
didn't work for me. I get
fatal: 'femconcrete' does not appear to be a git repository
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
I am sure I am doing something stupid again.
Postby Kunda1 » Tue Apr 09, 2019 4:54 pm
git pull -X https://github.com/berndhahnebach/FreeCAD_bhb femconcrete
berndhahnebach :lol:
bernd
Postby bernd » Tue Apr 09, 2019 5:05 pm
harry did you sell the d of mine ... ? Hopefully you some good money for this :lol: :mrgreen:
HarryvL
Postby HarryvL » Tue Apr 09, 2019 6:51 pm
:shock: :lol:
HarryvL
Postby HarryvL » Wed Apr 10, 2019 4:09 am
Hi Bernd, I did a quick test (file attached) and found the following:
1) It looks like you added back in a standard directory for CCX file saving. However when you change that to your own directory it doesn't stick. So next time you want to save you get sent back to the default.
2) Concrete friction angle is not set to a default value. If left blank then FC crashes upon post processing
3) There is no unit specified for friction angle, so it is unclear if you need to put it in degrees or radians. If only a value is added (say 30) then again post processing crashes with:
 File "/home/harry/FC_Dev/Build/Mod/Fem/femresult/resulttools.py", line 381, in add_principal_stress_reinforced
    matrix_af = float(FreeCAD.Units.Quantity(obj.Material['AngleOfFriction']).getValueAs('rad'))
ValueError: Unit mismatch
4) Same issue as 2) above for yield strength of steel
5) If I manually correct the above (add friction angle 0.3 rad and yield strength 500 MPa) then I still get a crash in post processing:
  File "/home/harry/FC_Dev/Build/Mod/Fem/femresult/resulttools.py", line 384, in add_principal_stress_reinforced
    reinforce_ratio = float(obj.Reinforcement['ReinforcementRatio'])
KeyError: 'ReinforcementRatio'
Frame2D_BHB.FCStd
(354.65 KiB) Downloaded 3 times
OS: Ubuntu 16.04.5 LTS (Unity/ubuntu)
Version: 0.19.16428 (Git)
Build type: Unknown
Branch: femconcrete
Hash: a82fe5a724640e64383038eba43066cc07b88dce
Python version: 2.7.12
OCC version: 7.1.0
