Concrete branch ready for testing
bernd
Re: Concrete branch ready for testing
Postby bernd » Wed Apr 10, 2019 9:35 am
thanks harry for testing ...
HarryvL wrote:
Wed Apr 10, 2019 4:09 am
1) It looks like you added back in a standard directory for CCX file saving. However when you change that to your own directory it doesn't stick. So next time you want to save you get sent back to the default.
no, I did not switch back, I improved the directory handling once again. Seams not yet as good as the former one. :( Could you be more specific. What does not work for you?
2) Concrete friction angle is not set to a default value. If left blank then FC crashes upon post processing
3) There is no unit specified for friction angle, so it is unclear if you need to put it in degrees or radians. If only a value is added (say 30) then again post processing crashes with:
 File "/home/harry/FC_Dev/Build/Mod/Fem/femresult/resulttools.py", line 381, in add_principal_stress_reinforced
    matrix_af = float(FreeCAD.Units.Quantity(obj.Material['AngleOfFriction']).getValueAs('rad'))
ValueError: Unit mismatch
4) Same issue as 2) above for yield strength of steel
5) If I manually correct the above (add friction angle 0.3 rad and yield strength 500 MPa) then I still get a crash in post processing:
The short answer is https://github.com/berndhahnebach/FreeC ... #L344-L346
Check user inputs is one of the most import developments for a software and one which does not make much fun :) I will have a look.
HarryvL
Postby HarryvL » Wed Apr 10, 2019 10:41 am
I set up my own directory and save/run CCX. Then when I rerun CCX it has forgotten about my earlier choice and offers the standard directory again.
HarryvL
Postby HarryvL » Wed Apr 10, 2019 11:07 am
Thanks Bernd. I tried a few things, but I always get an error at post-processing stage. What material settings do I need to use to make my case run?
bernd
Postby bernd » Wed Apr 10, 2019 2:05 pm
Frame2D_BHB_for_harry.FCStd
(522.47 KiB) Downloaded 9 times
Reinforcement ration in x-direction
bernd
I added a commit which sets the min reinforcement ratio to 0.0 if not given. If you gone use the new materials "Concrete-Harry" and "Reinforcement-Harry" your files should be run.
cheers bernd
HarryvL
Postby HarryvL » Wed Apr 10, 2019 2:18 pm
Cool 😎. I didn’t see those materials in the list so simply chose concrete and steel. That must be the problem.
HarryvL
Postby HarryvL » Wed Apr 10, 2019 5:51 pm
Sorry Bernd, but there are no materials with such names in my drop-down list.
bernd
Postby bernd » Wed Apr 10, 2019 6:37 pm
have you activated all path in FEM material prefs?
bernd
Postby bernd » Wed Apr 10, 2019 7:11 pm
or use the most not smart method and copy the files from here https://github.com/berndhahnebach/FreeC ... 9f43b8eff3 to a path on your computer and activate the user defined material path in FEM mat pref.
HarryvL
Postby HarryvL » Thu Apr 11, 2019 5:48 pm
Yes I have, but still they don't show up. I will copy from the link you provided.
