Py3 Mac app for testing
peterl94
Re: Py3 Mac app for testing
Postby peterl94 » Thu Jan 03, 2019 1:43 pm
looo wrote:
Thu Jan 03, 2019 9:57 am
1. when you create the environment use an additional constraint: blas=*=openblas
Good to know, thanks.
2. conda ships static libs and shared libs together.
I didn't copy the whole environment. I adapted the "MakeMacBundleRelocatable.py" script, which uses otool to only copy referenced libraries.
3. Maybe it's also possible to ship calculix within the bundle.
Yes, and its been requested that Graphviz be included too.
Did building FreeCAD without this patch worked for you?
No. I patched it differently. Looking at it again, I see that Qt did it the same way. Maybe we can just include qprinter.h if it is not a private header.
diff --git a/src/Mod/Drawing/Gui/DrawingView.cpp b/src/Mod/Drawing/Gui/DrawingView.cpp
index bbfb05465..5d06c061b 100644
--- a/src/Mod/Drawing/Gui/DrawingView.cpp
+++ b/src/Mod/Drawing/Gui/DrawingView.cpp
@@ -65,6 +65,11 @@
 using namespace DrawingGui;
+#ifdef B0
+// termios.h on macOS defines B0 which conflicts with QPrinter::B0
+#undef B0
+#endif
 SvgView::SvgView(QWidget *parent)
     : QGraphicsView(parent)
     , m_renderer(Native)
https://github.com/qt/qtbase/blob/5.11/ ... nter.h#L54
looo
Postby looo » Fri Jan 04, 2019 8:09 am
Nice. Something Like this would be nice to have for linux and windows too.
Graphviz, calculix, gmsh should be available from conda. But as far as I know @sgrogan uses other builds for the windows bundle... So I guess it's up to whatever works best. But it would be also nice to get some feedback of the conda-packages.
Yes, your patch looksuch more advanced ;) . I added it to the conda-forge recipe. Hopefully this is ok for you.
sgrogan
Postby sgrogan » Fri Jan 04, 2019 11:56 pm
I copy manually from the env, but I should be able to come up with a script. I will try in Python.
I believe @triplus copies the env and deletes stuff for the AppImage?
Now I don't bundle Graphviz. I use other calculix, gmsh and ifcopenshell because they are statically linked and I can use the same version for the VS2013 builds.
Travis supports Windows now, so it would be great if we could provide weekly portable builds (.dmg, .7z, AppImage) packaged from @looo's conda builds. This would be the closest we've ever had to a unified version. If we could make this work, I would suggest we use this for the official 0.18 release. Note, QT5 might be older than what otherwise might be available.
I think in the short term we should still use more "native" package managers (HomeBrew, LibPack, Ubuntu packages) for the CI (pull-request builds).
We get a lot of coverage this way. Oldest to newest almost. In the future maybe we can run the self tests on the Conda based builds, at first I would deploy in spite of any errors.
Thanks @looo, we are only to this point because of your effort and skill :!: :D
looo
Postby looo » Sat Jan 05, 2019 2:15 pm
I guess the best would be to find a way that works for all platforms. The script from @peterl94 is the most advanced way so maybe we can find alternatives for windows and linux (alternatives to otool)
This would be indeed nice to have. The old qt5 might be a problem and we should maybe first try to update to qt5.9 if this is of any help. I guess using the qt5.9 from anaconda should work and all we need is to update pyside2, (soqt), pivy. But no idea if this will fix the problems currently occuring on windows (missing images on startpage) and mac (some problems on high-resulution-screens).
I think so too. It's nice to have a stable base. But updating a stable base is difficult (see the current efforts to update the ppa). I guess having alternative strategies for building freecad is not a bad strategy.
Site Admin
Postby wmayer » Sat Jan 05, 2019 2:53 pm
On Windows it's Dependency Walker (depends.exe) which can be used also in console mode. With the option /oc:<path> a file in csv format is created which can easily parsed to find the dlls.
However, you only get a dll if another dll links to it. Plugin dlls (e.g. all the Qt plugins) cannot be fetched this way because they are loaded at runtime.
leonardshelby
Postby leonardshelby » Mon Jan 07, 2019 9:00 pm
Nice to see you guys working on new builds for mac :)
I'm afraid the freezes on macos 10.14.x are still here when launched from finder. It is not a big issue as there are workarounds, I just wanted to leave the feedback.
sgrogan
Postby sgrogan » Mon Jan 07, 2019 11:25 pm
Maybe? https://cmake.org/cmake/help/v2.8.8/cma ... eUtilities fixup_bundle can maybe handle the plugins?
sgrogan
Postby sgrogan » Fri Mar 01, 2019 12:26 am
I use this to create a new environment
conda create --name freecad-dev3 python=3.6 tbb=2018.0.5 occt=7.3 freecad -c freecad/label/dev
What should it be for openblas?
triplus
Postby triplus » Fri Mar 01, 2019 12:45 am
Just add it like:
conda create --name freecad-dev3 blas=*=openblas python=3.6 tbb=2018.0.5 occt=7.3 freecad -c freecad/label/dev
jmborer
Postby jmborer » Sat Mar 09, 2019 7:38 pm
To run this version you need to create an environment that retrieves the latest DEV version of freecad:
Then activate this env:
conda activate freecad-dev3
Finally install FreeCAD:
conda install freecad
And run it:
freecad
