clear mesh does not work for Netgen meshes anymore
bernd
Postby bernd » Wed Jan 09, 2019 11:34 am
see title, file attached ...
Version: 0.18.15572 (Git)
Hash: ab1f4c442d443adae106a2ea1ed877f33db86154
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Switzerland (de_CH)
clear_mesh.FCStd
(25.8 KiB) Downloaded 13 times
Edit: see post for Python code to do the above: https://forum.freecadweb.org/viewtopic. ... 83#p279183
fandaL
Re: clear mesh does not work for Netgen meshes anymore
Postby fandaL » Wed Jan 09, 2019 1:29 pm
Cleaning Box_Mesh does not work for
Version: 0.18.15252 (Git)
Hash: 652e1dbdd0fb74f1d3df8034254281df9c24aae6
Qt version: 5.6.2
Locale: Czech/CzechRepublic (cs_CZ)
But it works for older version
Version: 0.18.14993 (Git)
Hash: 1e6818b6fbf86ad08d8fc85252dddcae8891dd54
Qt version: 5.6.2
looo
Postby looo » Wed Jan 09, 2019 3:39 pm
stupid question:
how to clear/clean a mesh?
bernd
Postby bernd » Wed Jan 09, 2019 3:45 pm
stupid question:
activae FEM workbench. Select the mesh in tree view, clear mesh. If you use german FreeCAD it is translated with Netz löschen, which is wrong.
bernd
Postby bernd » Thu Jan 10, 2019 8:41 am
something must have been changed in FreeCADs recomputes ...
import Fem
FreeCAD.open(FreeCAD.ConfigGet("AppHomePath") + 'data/examples/FemCalculixCantilever3D.FCStd')
App.ActiveDocument.Box_Mesh.FemMesh = Fem.FemMesh()
works great, teh mesh is cleared, but as soon as the document is recomputed by
the mesh appears again.
A workaround would be to comment this line: https://github.com/FreeCAD/FreeCAD/blob ... ds.py#L528
But the problem is at a recompute the Shape will be remeshed immediately which could go for a looooong time and thus the user has to kill FreeCAD because this is not what the user wants probaly. It should be possible to mark the mesh if it should be meshed on next recompute or not.
bernd
Site Admin
Postby wmayer » Thu Jan 10, 2019 11:52 am
There were some problems with the old recompute mechanism where features could be set as touched but the tree view didn't show this with the overlay icon. This is because the mustExecute was not correctly implemented or not implemented at all. Then a regression was introduced with v0.17 where objects are superfluously recomputed and thus took a lot of time.
Thus, the recompute mechanism has been reworked to be more robust against possible incorrect implementations of module feature and to reduce superfluous recomputes.
The misbehaviour in FEM now just demonstrates that things work as expected. :D
To restore the old behaviour you only have to change a single line:
In FemMeshObject.cpp declare FemMesh not as Prop_None but as Prop_NoRecompute or Prop_Output.
bernd
Postby bernd » Tue Jan 15, 2019 11:49 am
