GMSH error
HarryvL
GMSH error
Postby HarryvL » Thu Jan 10, 2019 5:12 pm
In recent days I get the following error from GMSH. It happens consistently. Am i alone in this?
0.0: We are going to start ...
0.1: Start Gmsh ...
4.7: Gmsh had warnings ...
4.7: Error : Unknown string option 'Solver.Extension0' Error : Unknown string option 'Solver.Extension1' Error : Unknown string option 'Solver.Extension2' Error : Unknown string option 'Solver.Extension3' Error : Unknown string option 'Solver.Extension4' Error : Unknown string option 'Solver.Extension5' Error : Unknown string option 'Solver.Extension6' Error : Unknown string option 'Solver.Extension7' Error : Unknown string option 'Solver.Extension8' Error : Unknown string option 'Solver.Extension9'
4.7: Gmsh done!
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15609 (Git)
Build type: Unknown
Hash: c03d8a48034ec3306fc9b3f19d96b4648f0d78a5
Python version: 2.7.12
OCC version: 7.1.0
bernd
Re: GMSH error
Postby bernd » Thu Jan 10, 2019 5:45 pm
which version of gmsh?
HarryvL
Re: GMSH error
Postby HarryvL » Thu Jan 10, 2019 5:58 pm
How can I find out?
PrzemoF
Re: GMSH error
Postby PrzemoF » Thu Jan 10, 2019 6:05 pm
From command line:
$ gmsh --version
3.0.6
or just start gmsh and go Help->About
HarryvL
Re: GMSH error
Postby HarryvL » Thu Jan 10, 2019 6:11 pm
Interestingly it returns this:
$ gmsh --version
2.10.1
PrzemoF
Re: GMSH error
Postby PrzemoF » Thu Jan 10, 2019 6:20 pm
OK, that's funny :D
I dont's have a ubuntu virtual machine to test it, so please be careful. I hope that gmsh comes in package named gmsh :D
sudo apt-get install --reinstall gmsh
If that doesn't help, you can go and nuke it from the orbit:
sudo apt-get purge gmsh && sudo apt-get install gmsh
Edit: What happens if you try to start gmsh from the command line?
HarryvL
Re: GMSH error
Postby HarryvL » Thu Jan 10, 2019 6:21 pm
I found a later version in the Calculix directory and this gives the same error when run from command line:
~/CLCX-caelinux64/bin/gmsh-3.0.6-Linux64/bin$ gmsh
PrzemoF
Re: GMSH error
Postby PrzemoF » Thu Jan 10, 2019 6:24 pm
Maybe some config file... try to move somewhere file ~/.gmshrc
Also there might be some more info in ~/.gmsh-errors
Edit: in ~/.gmsh there is a section with something that is likely linked to your problem:
Solver.Extension0 = ".pro";
Solver.Extension1 = "";
Solver.Extension2 = "";
Solver.Extension3 = "";
Solver.Extension4 = "";
Solver.Extension5 = "";
Solver.Extension6 = "";
Solver.Extension7 = "";
Solver.Extension8 = "";
Solver.Extension9 = "";
HarryvL
Re: GMSH error
Postby HarryvL » Thu Jan 10, 2019 6:29 pm
OK, that's funny :D
Wonderful that worked for FreeCAD - thanks @PrzemoF, but I still have the same error on the command line in the CCX directory. Anyway, meshes come out ok, so no practical impact. I will follow up on your suggestion.
