[solved]Cannot open add-on manager
Vicolaships
Postby Vicolaships » Sun Jan 13, 2019 5:05 pm
I cannot open the add-on manager in FreeCAD:
$ freecad
FreeCAD 0.17, Libs: 0.17R13541 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/victor/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/lib/freecad/Mod/Ship/InitGui.py
Please look into the log file for further information
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/victor/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/lib/freecad/Mod/Plot/InitGui.py
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/victor/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/lib/freecad/Mod/Draft/InitGui.py
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/victor/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/lib/freecad/Mod/Tux/InitGui.py
During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/victor/.local/lib/python2.7/site-packages/PySide2/QtCore.so) occurred in /usr/lib/freecad/Mod/Arch/InitGui.py
/usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /home/victor/.local/lib/python2.7/site-packages/PySide2/QtGui.so)
Running the Python command 'Std_AddonMgr' failed:
  File "/usr/lib/freecad/Mod/AddonManager/AddonManagerGui.py", line 10, in Activated
    import AddonManager
  File "/usr/lib/freecad/Mod/AddonManager/AddonManager.py", line 40, in <module>
  File "/usr/lib/freecad/Ext/PySide/QtCore.py", line 1, in <module>
    from PySide2.QtCore import *
I'm using Kubuntu 18.04 and the FreeCAD stable PPA.
OS: Ubuntu 18.04.1 LTS
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.15rc1
Qt version: 5.9.5
Locale: French/France (fr_FR)
$ dpkg -l | grep -i freecad
ii  freecad                                              1:0.17.13541-1ppa10~ubuntu18.04.1                  amd64        Extensible Open Source CAx program (beta)
How can I make it work again ? (it worked before!)
I have deleted all my preferences and re-installed FreeCAD again but it still does not work:
sudo apt remove --purge freecad
rm ~/.FreeCAD/ ~/.config/FreeCAD/ -rf
sudo apt install -y freecad
I experience the same problem with the freecad-daily version.
Feel free to ask for information if you miss some!
Thanks
yorik
Site Admin
Re: Cannot open add-on manager
Postby yorik » Mon Jan 14, 2019 4:28 pm
It looks like there is some Qt version mismatch there: your FreeCAD is using 5.9, but your pyside2 package wants 5.11...
Where does /home/victor/.local/lib/python2.7/site-packages/PySide2/QtCore.so come from?
Vicolaships
Postby Vicolaships » Mon Jan 14, 2019 6:05 pm
I don't know but I have deleted these local packages and it now works! Thanks for the hint
Re: [solved]Cannot open add-on manager
Postby Kunda1 » Mon Mar 04, 2019 11:46 am
Please mark this thread as [Solved] by adding it to the title of the first post in this thread. Thanks.
