(solved) FreeCAD 0.18: Bug delete Part
user1234
Postby user1234 » Tue Jan 15, 2019 8:27 pm
Hello!
I possibly found a very, very small bug.
When i delete the Part in this file (yes, PartDesign and Part mixed), the FreeCAD window freezes (but not the menu).
FC++ exception thrown (basic_string::_M_construct null not valid)Traceback (most recent call last):
<class 'Base.FreeCADError'>: FC++ exception thrown (basic_string::_M_construct null not valid)
When i delete all bodies one by one, i only get errors that FreeCAD does not find the origins.
Version
OS: Debian GNU/Linux buster/sid
Version: 0.18.15640 (Git)
Hash: d94fc4988e2d26ea9ef65b09cc84f1f287411181
Python version: 3.7.2
Qt version: 5.11.3
Sorry for bad english
Greetings
user
error.FCStd
(32.15 KiB) Downloaded 3 times
Site Admin
Re: FreeCAD 0.18: Bug delete Part
Postby wmayer » Tue Jan 15, 2019 11:41 pm
I disagree that its a small bug, IMO it's a critical one.
The problem with the current implementation is that due to use of a std::set the order of removal can become arbitrary (the sort criterion is the memory address) and in case the Group object comes before the Helix objects we run into a double destruction. Especially if Undo/Redo is disabled the objects will be destroyed immediately and thus will create dangling pointers.
With git commit 6e5369da3 this should be fixed.
user1234
Postby user1234 » Wed Jan 16, 2019 6:29 am
Hello!
Thank you for the extreme fast fix! It works.
Greetings
user
