TechDraw: file opening time
koluna
Re: TechDraw: file opening time
Postby koluna » Fri Feb 15, 2019 6:39 am
Thanks.
Can You answer the question upper?
wandererfan
Postby wandererfan » Fri Feb 15, 2019 1:37 pm
Which one?
koluna
Postby koluna » Sun Feb 17, 2019 7:05 am
Which one?
It is from Wiki:
Do not cut, copy and paste TechDraw objects in the tree view as this generally does not work out well.
Can You tell me, I may cut/copy/paste objects (views, labels) between pages?
wandererfan
Postby wandererfan » Sun Feb 17, 2019 9:16 pm
No. When you paste, the links between the pasted object and the page are not created. You will get an extra View in the tree, but there is no easy way to move it under a Page.
easyw-fc
Postby easyw-fc » Fri Aug 16, 2019 7:50 am
wandererfan wrote:
Wed Jan 23, 2019 2:02 pm
There is a preference setting "Keep Pages Up to Date". If you uncheck this, pages will not do any processing and your load time should go down.
Once you are ready to produce drawings, recheck the option and recompute the pages.
Hi @wandererfan
I tried to save a FC file with the Page option KeppUpdated to False,
but it seems that when I re-open the file, the Page get marked to be recomputed, and the parameter changes to True.
FC then will recompute the Page, increasing the loading time.
Am I missing something?
Thanks in advance
Maurice
My FC daily latest info:
OS: Linux Mint 19.2 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
wandererfan
Postby wandererfan » Fri Aug 16, 2019 1:14 pm
Is your KeepUpdated preference set to True? Looks like the code gives priority to the preference instead of the setting on the Page.
I'll add this to the list. Thanks for finding it!
