FreeCAD 0.18 Python3 bindings
donjan
Postby donjan » Wed Jan 23, 2019 6:38 pm
Testing 0.18 from the daily repo on Ubuntu:
$ export PYTHONPATH=/usr/lib/freecad-daily/lib && python3
Python 3.6.7 (default, Oct 22 2018, 11:32:17)
[GCC 8.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import FreeCAD
  File "<stdin>", line 1, in <module>
ImportError: dynamic module does not define module export function (PyInit_FreeCAD)
It works as usual when invoking python2 instead.
The console mode also goes for Python2:
$ /usr/lib/freecad-daily/bin/FreeCADCmd
[SNIP]
>>> import sys; print(sys.version)
2.7.15rc1 (default, Nov 12 2018, 14:31:15)
[GCC 7.3.0]
Other libs I'd like to import in the same scripts are dropping Python2 support soon (https://python3statement.org/), or already have done so (numpy and FEniCS in my case).
Can the daily be built with Python3 bindings (pretty please)?
Or is there another method to monkey-patch this short of building FreeCAD myself?
kkremitzki
Re: FreeCAD 0.18 Python3 bindings
Postby kkremitzki » Thu Jan 24, 2019 12:11 am
It's coming soon. I have an experimental dual-build Python 2 & 3 FreeCAD 0.18 available in my personal PPA at https://launchpad.net/~kkremitzki/+archive/ubuntu/ppa but you may run into issues.
donjan
Postby donjan » Thu Jan 24, 2019 4:23 pm
After purging the main repo package and installing from your PPA, I get:
$ export PYTHONPATH=/usr/lib/freecad/lib && python3
import FreeCAD
FreeCAD 0.18, Libs: 0.18R
No modules found in /usr/lib/freecad-python3/Mod
During initialization the error No module named 'freecad' occurred
Now despite the error I can load the .so modules and do some work:
>>> doc = FreeCAD.newDocument('testDoc')
>>> doc.load('/home/donjan/Desktop/test.fcstd')
<unknown exception traceback><class 'ModuleNotFoundError'>: No module named 'BOPTools'
<unknown exception traceback><class 'ModuleNotFoundError'>: No module named 'CompoundTools'
Importing project files......
>>> print(doc.Objects[0].Label)
Box
But the Python modules have issues:
>>> import Draft
ModuleNotFoundError: No module named 'Draft'
The import Draft error can be fixed with:
sudo ln -s /usr/lib/freecad/Mod /usr/lib/freecad-python3/Mod
The "During initialization the error No module named 'freecad' occurred" error can be disappeared with:
sudo ln -s /usr/lib/freecad/Ext /usr/lib/freecad-python3/Ext
It works for my purposes right now, but no idea how shaky all of this is :)
Thanks!
And soon == ?
