Trouble with compilation on ArchLinux (typeError: type '_io._IOBase' )
Yinameah
Postby Yinameah » Mon Jan 28, 2019 6:55 pm
I spent some time trying to compile FreeCAD and I run into problems. It's the first time I dig into CMake seriously and I'm still a bit lost, but I have a decent understanding of all the other techs involved.
First, I had trouble to find the proper dependencies. https://www.freecadweb.org/wiki/index.p ... pileOnUnix was not up to date concerning which packages where not available in the main repos.
Using AUR and a lot of trial and error, I finally managed to compile FreeCAD but on startup I get :
[Error in InitApplications type '_io._IOBase' participates in gc and is a base type but has inappropriate tp_free slot
File "<string>", line 241, in <module>
File "<string>", line 54, in InitApplications
File "/usr/lib/python2.7/io.py", line 51, in <module>
import _io
TypeError: type '_io._IOBase' participates in gc and is a base type but has inappropriate tp_free slot
I saw similar error in the forum thread about Python3 compilation, but I'm not trying to compile with pyhon3 sofar.
I think it's related to pyside/shiboken, because cmake gives me the following while configuring :
Using default python: .cpython-37m-x86_64-linux-gnu
libshiboken built for Release
Found PySide Tools: /usr/bin/pyside-uic, /usr/bin/pyside-rcc
On the other hand, I succeed to build with "BUILD_QT5=ON". In that case, cmake gives me :
PYTHON_CONFIG_SUFFIX: -python2.7
And everything goes well (At least compilation doesn't fail and freecad doesn't crash at startup)
Any thoughts ? Am I right to think that the problem is because pyside/shiboken use python3 instead of python2 ? Is that because I don't have the right dependencies or because of a FreeCAD cmake configuration issue ?
PS : I cloned the git repository for the sources. (upstream https://github.com/FreeCAD/FreeCAD.git -- branch master)
rradler
Re: Trouble with compilation on ArchLinux (typeError: type '_io._IOBase' )
Postby rradler » Wed Mar 13, 2019 6:15 am
I had exactly the same problem as you. For compiling freecad I followed the instructions on the freecad wiki. It would then compile without any problems but crash at startup. The "BUILD_QT5=ON" switch made it then start without crashing. I didn't try much with it but as far a I can see there is an issue with some of the icons in the menu bar. But this problem also shows up in the AppImage version with Conda/phyton3.
Postby Kunda1 » Mon Jul 22, 2019 11:49 am
This looks like a python2/3 issue. Can you try building with python3 instead ?
