Missing possibilities to enter expressions
Postby chrisb » Tue Jan 29, 2019 12:33 am
There are several places in FreeCAD where I would expect the possibility to enter an expression. If there isn't a special reason why this should be so, then I would collect all of these places and create a ticket. I would guess to fix them one after another is easier than doing it intermittingly.
This is probably rather a 0.19 topic than 0.18, because there is no show stopper among them.
  • Placement panel: all input fields should have expressions like they have in the property panel.
  • PartDesign: additive and subtractive primitives, their individual values such as radius, height, width, length as well as pitch, yaw, roll
  • Part.Extrude; all numeric input fields.
  • Part.Revolve; all numeric input fields.
  • Part.Mirror; x, y, z
  • Part.Fillet; start and end radius. This might be difficult, as the values are somehow copied to a list.
  • Part.Chamfer; same situation as with fillets.
  • Part.Thickness.
Edit: Updated list:
chrisb wrote:
Sun May 19, 2019 5:35 am
uwestoehr
Re: Missing possibilities to enter expressions
Postby uwestoehr » Fri May 17, 2019 5:26 pm
  • Part.Thickness.
I also vote to add them. However in the first step the fillet and chamfer dialog should should be postponed (the other ones are straight forward).
I also stumbled over some missing expressions today: https://forum.freecadweb.org/viewtopic.php?f=3&t=36458
GlouGlou
Postby GlouGlou » Fri May 17, 2019 5:35 pm
I agree, except for fillet and chamfer, it seems probably never useful and working right :D
DeepSOIC
Postby DeepSOIC » Fri May 17, 2019 6:15 pm
To support an equation, there must be a direct relation between the value of an input field and a property of some object.
Hard to do, as the placement dialog has some values that don't directly relate to properties. Placement dialog offers things like center of rotation, yaw-pitch-roll values and "apply incremental changes" checkbox, which break/don't have a direct relation to properties.
Doable, except for roll-pitch-yaw. Roll-pitch-yaw is a little difficult beast, it may be possible to bind expressions to them, but I'm not sure.
Doable. I think...
Part.Thickness.
Already has one, doesn't it?
probably doable, but I'm not sure.
Please don't assume that I have just promised to add that myself :mrgreen:
Postby chrisb » Fri May 17, 2019 8:57 pm
This is covered by bullet point two, or isn't it?
openBrain
Postby openBrain » Fri May 17, 2019 10:26 pm
My guess is that it is. ;)
Postby chrisb » Sun May 19, 2019 5:35 am
Updated list from first post, removed thickness and Placement, even X, Y, Z are not directly connected to properties, the depend on the rotation.
Postby chrisb » Sun May 19, 2019 5:45 am
And here is the ticket: issue #3981.
