[SOLVED] Request for 2 new icons: Draft join and split
Moderator: agryson
Moult
Postby Moult » Tue Jan 29, 2019 12:31 pm
Good morning all! I am building two new features for the Draft workbench: the join and split tool. The join tool is where you can take two wires and if they are joined at one end, it will join them into a single wire. This is a typical tool in most CAD software. The split does the opposite - you can take a wire and split it into two wires at a point.
This is the PR: https://github.com/FreeCAD/FreeCAD/pull/1936
Is there an artist who can please help make two icons for these two functions?
bitacovir
Re: Request for 2 new icons: Draft join and split
Postby bitacovir » Tue Jan 29, 2019 1:42 pm
Hi, I will happy to help you.
Do you have a symbol in mind?
I know that join in CAD is something like this: https://www.iconfinder.com/icons/124350 ... _join_icon
And split is something like this: https://www.iconfinder.com/icons/778153 ... split_icon
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
Postby chrisb » Tue Jan 29, 2019 1:55 pm
Where is the difference to Draft->Upgrade?
bitacovir
Postby bitacovir » Tue Jan 29, 2019 2:26 pm
What about a quick combination of FreeCAD Icon elements:
Draft Join Tool
Draft Split Tool
Draft_Join.svg
(17.94 KiB) Downloaded 107 times
Draft_Split.svg
(16.91 KiB) Downloaded 111 times
::bitacovir::
My old Blog
Moult
Postby Moult » Tue Jan 29, 2019 8:39 pm
Hey thanks! The Icons look great!
The upgrade and downgrade tool actually converts the object to another type. It is certainly possible to join and split a line by a series of combination of upgrades, downgrades, and convert to sketch, but it is a multiple step process. In architectural drafting, this join and splitting function is done hundreds of times a day, and so it is useful to have it in one tool.
This is the thread that started it:
https://forum.freecadweb.org/viewtopic. ... 9&start=20
triplus
Postby triplus » Tue Jan 29, 2019 10:08 pm
Nice to see Draft workbench getting some new features.
@bitacovir
Thanks for the artwork.
carlopav
Postby carlopav » Wed Jan 30, 2019 8:08 am
Great!
What about if the tool could work also on lines that are not joined at one end, and extend automatically both to the intersection point?
Moult
Postby Moult » Wed Jan 30, 2019 8:27 am
I believe what you are describing is a trim / extend / chamfer tool, at least in AutoCAD / Revit lingo that's what it is :) I will play around with the trim tool and see if it is sufficient.
The icons have now been committed to the PR. Thanks very much!
bitacovir
Re: [SOLVED] Request for 2 new icons: Draft join and split
Postby bitacovir » Wed Jan 30, 2019 10:32 am
You are welcome.
::bitacovir::
My old Blog
yorik
Site Admin
Postby yorik » Wed Jan 30, 2019 12:54 pm
Nice icons!!
The trim/extend tool should also gain some love.. Many people find it tricky to use, basically because (I think) although it has the same name as autocad, it doesn't behave like autocad (select boundaries first). But I find it more interesting how it is now...
Also, that tool is also able to extrude if you select a face. That has actually nothing to do with trimming, maybe it should be separated into a different tool...
