[SOLVED] Request for 2 new icons: Draft join and split
Moderator: agryson
bitacovir
Re: [SOLVED] Request for 2 new icons: Draft join and split
Postby bitacovir » Wed Jan 30, 2019 3:12 pm
yorik wrote:
Wed Jan 30, 2019 12:54 pm
Nice icons!!
Also, that tool is also able to extrude if you select a face. That has actually nothing to do with trimming, maybe it should be separated into a different tool...
Thank you.
I love that feature (face extrusion with trimming). It is like Sketchup. I agree that this feature should be a more relevant tool.
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
regis
Postby regis » Wed Jan 30, 2019 4:38 pm
beautiful development here. I'm loving this additions on the Draft workbench.
regis
Postby regis » Wed Jan 30, 2019 5:36 pm
The trim/extend tool should also gain some love
I so much agree.
Thats true, it works on lines and faces. but for some reason it doesn't work on planer objects. A bit counter intuitive there.
Screenshot from 2019-01-30 12-33-25.png (126.07 KiB) Viewed 231 times
carlopav
Postby carlopav » Wed Jan 30, 2019 10:04 pm
Moult wrote:
Wed Jan 30, 2019 8:27 am
I believe what you are describing is a trim / extend / chamfer tool, at least in AutoCAD / Revit lingo that's what it is :)
Ahaha... I'm not so original indeed... But that would be really useful I think! I like the actual behaviour of the trimex on lines better than the autocad one!
That would be also a very cool feature. Maybe when applied to a solid it should move the face in the normal direction if possible instead of extruding it? To make it most consistent throughout different objects.
regis
Postby regis » Wed Jan 30, 2019 11:10 pm
Good point, I think there is also value in having both options available i.e to just extrude and or just stretch the face. So maybe having a box to check that says extrude when we click to the Trim/Extrude command to Move/Stretch the face?
Screenshot from 2019-01-30 18-11-33.png (370.81 KiB) Viewed 202 times
