Gyroid
microelly2
Gyroid
Postby microelly2 » Tue Jan 29, 2019 6:06 pm
for gyroid see https://youtu.be/VIcZdc42F0g
the model is created by 3 sketches to generate a Surface and a lot of Draft arrays.
schupin
Re: Gyroid
Postby schupin » Tue Jan 29, 2019 6:15 pm
Nice, I'm playing with TPMS based structures at work :)
I'm using trigonometry approximations to find the surfaces. How did you made it ? You solved the plateau's law or find some approximations ?
microelly2
Re: Gyroid
Postby microelly2 » Tue Jan 29, 2019 7:13 pm
I use scipy minimize to find the minimum area surface
# finde otimale innenpole
import numpy as np
import scipy
from scipy.optimize import minimize
methods=[
			'Nelder-Mead' ,
			'Powell' ,
			'CG' ,
			'BFGS' ,
			'L-BFGS-B',
			'TNC',
			'COBYLA',
			'SLSQP',
alpha=[App.ActiveDocument.BePlane.Shape.Face1.CenterOfMass]*4
ptsa=np.array(App.ActiveDocument.BePlane.Shape.Face1.Surface.getPoles())
def areaMin(alpha):
	'''function to minimize'''
	poles=ptsa
	alpha=alpha.reshape(2,2,3)
	poles[1:3,1:3]=alpha
	bs=Part.BSplineSurface()
	bs.buildFromPolesMultsKnots(poles,[4,4],[4,4],[0,1],[0,1],False,False,3,3)
	return bs.toShape().Area
for method in methods:
	tol=10**5
	rc=minimize(areaMin,alpha,method=method,tol=tol)
	print (rc.success,rc.message)
	alpha=np.array(list(rc.x)).reshape(2,2,3)
	poles=ptsa
	Part.show(bs.toShape())
	new=bs.toShape().Area
	old=App.ActiveDocument.BePlane.Shape.Area
	print (method," improvement %",round((old-new)/old*100,2),new)
For the gyroid I use 4 x 7 poles nurbs, it's a little bit more complex but the same idea.
hammax
Re: Gyroid
Postby hammax » Wed Jan 30, 2019 6:45 am
… had also my "close encounters of the third kind" with gyroid.
But I only used surface-tool. Is the result of surface minimal?
Gyroid_n.FCStd
FC.18.15713
(217.63 KiB) Downloaded 34 times
microelly2
Re: Gyroid
Postby microelly2 » Wed Jan 30, 2019 8:06 am
I remember your solution. I don't know whether the surface wb calculates minimal surfaces.
My idea is to optimize a given surface by modifiing the inner poles to get a minimum area.
For small models scipy.optimize.minimize works.
I will have a look at surface wb faces again and try to optimize them.
microelly2
Re: Gyroid
Postby microelly2 » Wed Jan 30, 2019 2:40 pm
I have compared the surface result against the optimized scipy-version
Surface::GeomFillSurface is not a mimimal surface
Here the results for a 4 x 4 testcase
('Nelder-Mead', True, 'Optimization terminated successfully.', 16080.548992338268)
('Powell', True, 'Optimization terminated successfully.', 15643.54680362999)
('CG', True, 'Optimization terminated successfully.', 15643.54680362999)
('BFGS', True, 'Optimization terminated successfully.', 15643.54680362999)
('L-BFGS-B', True, 'CONVERGENCE: NORM_OF_PROJECTED_GRADIENT_<=_PGTOL', 15643.54680362999)
('TNC', True, 'Local minima reach (|pg| ~= 0)', 15643.54680362999)
('COBYLA', True, 'Optimization terminated successfully.', 15708.577614427331)
('SLSQP', True, 'Optimization terminated successfully.', 15708.577614427331)
>>> suf=App.ActiveDocument.addObject("Surface::GeomFillSurface","Surface")
>>> suf.BoundaryList=[App.ActiveDocument.Shape003,('Edge4','Edge3','Edge2','Edge1')]
>>> _=App.activeDocument().recompute()
>>> suf.Shape.Area
15773.11692233747
There is no big difference but it is a difference 15773 and 15643
yellow:Surface WB, pink optimized
Surface WB - nice structure
minimum surface - not so nice
hammax
Re: Gyroid
Postby hammax » Thu Jan 31, 2019 8:28 am
… to get minimal surfaces, the soap bubble should be the physical method.
I only used arcs for the border lines in the elemental gyroid-cube.
Applying a curvature comb, there is a discontinuity at the cubes corners for arcs.
Should there be a better solution when using sinus curves? (But which amplitude???)
microelly2
Re: Gyroid
Postby microelly2 » Thu Jan 31, 2019 8:52 am
I do experiments with a 4 x 9 nurbs where I start with arcs (Bezier approx.) as borders too.
in a next step I will modify the border segment to other Bezier curves and compare the results.
this all can be reduced parametric to one sketch with 4 points, so experiments will become simple.
hammax
Re: Gyroid
Postby hammax » Thu Jan 31, 2019 11:30 am
… I tried to draw such a gyroid basic edge by sketching some sinus like curve with BSpline.
To control the amplitude only one value must be changed in the master sketch.
The clones are following the master. => primary cube cell
8 primaries (4 placements, 4 mirrored placements) => secondary cube cell.
+stereo
Gyroid_sin_0.FCStd
FC.18.15713
(237.38 KiB) Downloaded 40 times
