Creating a Part from an Existing FreeCAD Model
hooshsim
Postby hooshsim » Fri Feb 01, 2019 11:24 pm
Looking for some directions on how to create a geometry and add it to the existing part (FreeCAD 0.17, Windows 7, Release 8/2018).
The intent is to fill the notch using the curves and highlighted faces.
Thanks in advance - HooshSim
Stiffening.FCStd
(681.99 KiB) Downloaded 12 times
bejant
Re: Creating a Part from an Existing FreeCAD Model
Postby bejant » Sat Feb 02, 2019 2:23 am
One way:
In the Part WB, click the Shapebuilder tool:
  • Choose the "Face from edges" radio button.
  • Select the 3 edges on top. and click the Create button.
  • Make another face on the bottom, then one more face on the end.
  • Click the "Shell from faces" radio button.
  • Select the top or bottom face you just created, press Spacebar to hide it, and click the other two faces you created, and the two inside faces of the model.
  • Click the Create button.
  • Click the "Solid from shell" radio button.
  • Click the Model tab and in the history tree select Shell.
  • Click the Tasks tab to go back to the Shapebuilder tool, then click the Create button.
  • Click the Close button to exit the Shepebuilder tool.
20190201a-stiffening.FCStd
(847.63 KiB) Downloaded 5 times
From the Part WB, use the Booleans tool;:
or the Boolean Union tool:
to make a Fusion of Solid and Common.
OS: Ubuntu 18.04.1 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.15rc1
Qt version: 5.9.5
Postby chrisb » Sat Feb 02, 2019 6:42 am
How comes that I cannot take the 4-sided front as the hidden face, but only one of the triangulars?
bejant
Postby bejant » Sat Feb 02, 2019 2:19 pm
I don't know... the Face has to be visible when selecting it. Selecting, from the history tree, a Face that has visibility toggled to Off isn't working for me using the 0.17 version listed below. I haven't tried using my 0.18 version.
Qt version: 5.9.5
Postby chrisb » Sat Feb 02, 2019 2:24 pm
I meant something different.
In your description you open the top or bottom face to make the inside available. That works for me. But if I select the rectangular front and do exactly the same it doesn't work.
bejant
Postby bejant » Sat Feb 02, 2019 2:40 pm
Hmmm... I don't know why it's not working for you. After selecting the front face, then hiding it, I press Crtl to add the other Faces to my selection. Are you using a Mac, if so how do you add to the current selection? It works for me using the 0.17 version in my last reply, and works using this version of 0.18:
Qt version: 5.9.5
hooshsim
Postby hooshsim » Sat Feb 02, 2019 3:09 pm
Bejant,
Thank you. Appreciate the effort.
bejant
Postby bejant » Sat Feb 02, 2019 9:53 pm
You're welcome, post back if you need more help.
Postby chrisb » Sun Feb 03, 2019 1:55 am
Got it: After hiding the face I sometimes did not keep Ctrl (CMD on the Mac) pressed for the selection of the first additional face, thus removing the now hidden face from the selection.
Thanks for explaining.
bejant
Postby bejant » Sun Feb 03, 2019 8:41 pm
You're welcome, I wasn't very sure of exactly what you were doing.
