Gmsh error: Unknown element type for UNV export (MSH type 15)
uwestoehr
Postby uwestoehr » Sun Feb 03, 2019 4:29 pm
EDIT Bernd: I edited the Subject of this first post
GMesh broken in Conda_Py3QT5 build
to:
- open the attached file: https://forum.freecadweb.org/download/f ... w&id=76010
* at first with:
OS: Windows 7
Version: 0.18.15780 (Git)
Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e
Python version: 2.7.14
OCC version: 7.2.0
- double-click there on the Gmsh mesh and press in the appearing task "Apply" to recalculate the mesh
result: everything is fine
* now open the same file with:
OS: Windows 7
Python version: 3.6.6
Qt version: 5.6.2
result: the mesh generation failes:
Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid
I spent some time and are lost because I have not set up anything special, just use the official releases:
https://github.com/FreeCAD/FreeCAD/releases
and I assured that all preferences settings are on default.
Is this a bug or is Gmsh not yet ready for Python3?
Bimetall-Test.FCStd
(887.84 KiB) Downloaded 33 times
Jee-Bee
Re: GMesh broken in Conda_Py3QT5 build
Postby Jee-Bee » Sun Feb 03, 2019 8:05 pm
can you check if GMSH is available in the build. it should be in the bin folder (same as the freecad.exe) before it wasn't available. you can link to another GMSH if needed. GMSH don't care about python. python just tells how to execute GMSH.
But my own experience is that i never had GMSH to work with precompiled FC versions. (see https://forum.freecadweb.org/viewtopic.php?p=231656) What i remember is that it create a mesh but for some reason i won't be imported...
uwestoehr
Postby uwestoehr » Sun Feb 03, 2019 8:12 pm
For me GMSH works out of the box with the OCCT 7.2 release of 0.18.
For the Conda build I tried to use the latest GMSH 4.1.4 but also with this, it fails while it works for the OCCT 7.2 build.
Since I can work fine with the OCCT 7.2 build of FC I have no real troubles but maybe there is something to be fixed with the Conda build.
bernd
Postby bernd » Sun Feb 03, 2019 8:23 pm
Uwe for your infromation ...
gmsh mesh object works as follows ...
- FreeCAD geometry is exported to brep
- a geo file is written (Gmsh scripting language before Python but still supported)
- Gmsh is called with this geo file
- Gmsh writes an unv file
- FreeCAD reades the unv file
- if you watch the report output during meshing. the filenames are writen. In the geo file you will find the appropriate commands to run Gmsh with the geo and the brep geometry.
- With this you will easily find where the culprit is (In Gmsh, in FreeCAD, in SMESH (govern for unv writer) in OCCT (govern for brep writer and reader)) etc
cheers bernd
uwestoehr
Postby uwestoehr » Mon Feb 04, 2019 12:22 pm
Many thanks Bernd, I will try the next days if I can find out what makes the problem.
uwestoehr
Postby uwestoehr » Tue Feb 05, 2019 9:13 pm
Hi Bernd, I had now a closer look and I am puzzled because I get a successful run but nevertheless warnings:
Fem::FemMeshObjectPython / FEMMeshGmsh: Links go out of the allowed scope
We are going to start Gmsh FEM mesh run!
  Part to mesh: Name --> Box,  Label --> Box, ShapeType --> Solid
  CharacteristicLengthMax: 2.0
  CharacteristicLengthMin: 0.0
  ElementOrder: 2
  ElementDimension: 3
  C:\Users\USti\AppData\Local\Temp\Box_Geometry.brep
  C:\Users\USti\AppData\Local\Temp\Box_Mesh_TmpGmsh.unv
  C:\Users\USti\AppData\Local\Temp\shape2mesh.geo
  C:/Users/USti/Desktop/FreeCAD_0.18.15780_Conda_Py3QT5-WinVS2015_x64/bin/gmsh.exe
  No Group meshing for analysis.
  The Part should have a pretty new FEM mesh!
What means "Links go out of the allowed scope"?
Besides this the only thing I notice is that the path to the gmsh.exe uses slashes instead of backslashes. But this is the same for both FC builds.
The only difference between the Conda and normal build I see is in the unv-file and in the precision of the geo-file.
I attached the .geo, .unv, bprep and the .diff files of them in a ZIP file.
Do you have an idea what is going wrong?
Temp.zip
ZIP file with 9 files
(289.7 KiB) Downloaded 12 times
bernd
Postby bernd » Tue Feb 05, 2019 11:31 pm
The only idea I have is that the builds uses different gmsh binaries. Might be the conda build builds his own gmsh. If you did not change anything every build should use his provided gmsh. You can change the path in FEM prefs. Try to set the gmsh binary path to the one from the normal build and try the conda build. Does it work. You could do the other way too. Set the path to the conda gmsh and run the normal build. Does it fail? I would assume it is conda gmsh than ...
Never had this ...
uwestoehr
Postby uwestoehr » Wed Feb 06, 2019 1:20 am
Yes, this works.
When I set the gmsh of the conda build in the conda FC build it fails.
It might be that FC addresses GMSH in an outdated way because it works with GMSH 3.x (the normal FC build uses GMSH 3.0.6) and it fails with all versions of GMSH 4.x (the Conda build uses GMSH 4.0.7 and I also tried 4.1.3 and 4.1.4).
The question is if GMSH 4.x is declared ready to use. if yes, should I open a FC bug AND also report this to the GMSH developers?
Btw., what does "Conda" mean?
bernd
Postby bernd » Wed Feb 06, 2019 10:35 am
See last post, gmsh seams to have problems in conda build ...
looo wrote: PING
sgrogan wrote: PING
The guys above do far better know this than me. https://en.wikipedia.org/wiki/Conda_(package_manager)
uwestoehr
Postby uwestoehr » Wed Feb 06, 2019 10:58 am
Conda is not to blame. I tried the normal build of FC and tried there GMSH 4.0.7 and GMSH 4.1.4. And also the normal FC build fails with GMSH 4.x while it works fine with GMSH 3.x.
The error messages are the same as with the Conda build of FC.
cron
