Tool Addition to Workbench
Zig_mint
Postby Zig_mint » Sun Feb 10, 2019 8:13 pm
I am trying to make a custom workbench for myself that contains all the tools that I use regularly. I have created a module using the FreeCad build tool and its all working fine.
I wanted to know, how will I add already established tools of freecad?
for instance, I want my workbench to contain rectangle and circle sketching tools, How do I go about doing that?
microelly2
Re: Tool Addition to Workbench
Postby microelly2 » Mon Feb 11, 2019 10:07 am
You can load the moduls you want into your InitGui.py
try: # some methods from curve wb
			import ZebraTool
			import ParametricComb
			import GeomInfo
except: pass
cmds= ['ZebraTool','ParametricComb','GeomInfo','Nurbs_DraftBSpline Editor',
		'Nurbs_Create Shoe','Nurbs_Create Sole','Nurbs_Sole Change Model',
 #create your menu with the imported methods and your own m
self.appendMenu("Nurbs", cmds)
You only need to know the names of the commands you want.
Zig_mint
Postby Zig_mint » Mon Feb 11, 2019 4:31 pm
Thanks for the help but I wanted to specifically understand how can I import the "line tool" as the "Draft" and "Sketcher" workbench does.
GeneFC
Postby GeneFC » Mon Feb 11, 2019 7:13 pm
There is a wiki page that explains all the details.
https://freecadweb.org/wiki/Customize_Toolbars
Gene
