Ticket #3834 - Loss of coordinate systems during .stp (AP214) import/export
easyw-fc
Re: Loss of coordinate systems during .stp (AP214) import/export
Postby easyw-fc » Wed Feb 13, 2019 5:24 pm
The LCS should be then moved inside a Part
It would be nice to have it in an Import/Export STEP code ...
Site Admin
Postby wmayer » Wed Feb 13, 2019 6:01 pm
whocares
Postby whocares » Thu Feb 14, 2019 6:17 am
Great, i really appreciate your work.
I know this is not make a wish, but if the implementation is possible,
these Features wouldt be awesome too.
Add, move, orient, copy, name/rename and of course export these datum planes to a Step AP214.
For re/orientation i tried this -> plm.Placement.Rotation=App.Rotation(0,90,0,0)
and it worked so far.
Again, thank you!
whocares
Postby whocares » Wed Apr 03, 2019 1:23 pm
any News on this issue ?
easyw-fc
Postby easyw-fc » Sat Aug 17, 2019 1:08 pm
issue #3834
Hii wmayer,
would it be possible to switch from "App::Placement" to "PartDesign::CoordinateSystem"?
That would allow to work with assembly 4 approach, which is using "PartDesign::CoordinateSystem" to make assemblies...
plm=App.ActiveDocument.addObject("PartDesign::CoordinateSystem","CSW")
plm.Placement.Base=App.Vector(31.8244952147467,33.7921260930763,-162.824495214746)
plm=App.ActiveDocument.addObject("PartDesign::CoordinateSystem","MCS")
plm.Placement.Base=App.Vector(15.925,31.8500000000002,-82.48178698)
plm=App.ActiveDocument.addObject("PartDesign::CoordinateSystem","PCS")
plm.Placement.Base=App.Vector(7.105427357601E-15,1.04449782156735E-12,1.4210854715202E-13)
Moreover would it be possible to consider both import and export this LCS within STP?
Thx in advance
Maurice
exportwithnamedplanes-fc.FCStd
(13.71 KiB) Downloaded 23 times
Site Admin
Postby wmayer » Sat Aug 17, 2019 3:17 pm
Some months ago someone with a commercial CAD system already asked for this feature. It's listed in the bug tracker.
whocares
Postby whocares » Wed Sep 25, 2019 6:01 am
Hi, any Updates on this issue?
Kind regards
realthunder
Postby realthunder » Thu Oct 03, 2019 11:03 pm
I browsed through the OCC source code about this. I think it is quite doable. I'll add that feature once I got time.
Re: Ticket #3834 - Loss of coordinate systems during .stp (AP214) import/export
Postby Kunda1 » Fri Oct 04, 2019 12:58 am
Added ticket # to thread title and assigned ticket to @realthunder
realthunder
Postby realthunder » Mon Dec 30, 2019 10:45 pm
Copy my response from the other thread.
The STEP Axis information is part of the GD&T section. I did some research on how various other CAD handles this. I think FC is almost a blank in this area at the moment. Someone did a GD&T workbench some while ago based on Draft dimension, but was abandoned. And based on the look of the code, I decided not to continue the work. Instead, I plan to add basic GD&T support directly in Part workbench, maybe based on the existing Part measurement, to make them editable object and so on. But that is likely going to wait till the next release.
BTW, in case any one think its high priority and want to step in, you can checkout OCC source file XDEDRAW_GDTs.cxx, function DumpGDTs() to see how to extract various datum information from a XCAFDoc, which is what OCC imports STEP into.
