Union fails
Invictus
Union fails
Postby Invictus » Thu Feb 14, 2019 5:26 am
I'm trying to create a transition from a rectangle to a circle. I lofted 4 solids from each corner of the rectangle to the circle, and began to make unions of the solids, but the last solid could not be added to the union. Instead, it appears to give me the difference of the solids. What am I doing wrong? Could someone please help? Thanks.
Before union
After union
OS: Windows 7
Version: 0.17.13522 (Git)
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
Flue5.FCStd
(54.97 KiB) Downloaded 3 times
microelly2
Re: Union fails
Postby microelly2 » Thu Feb 14, 2019 7:08 am
Sometimes it helps to move one object a little bit (micrometer).
easyw-fc
Re: Union fails
Postby easyw-fc » Thu Feb 14, 2019 8:39 am
I made a boolean fragment and then created a solid from external faces
Flue5-solid.FCStd
(163.14 KiB) Downloaded 2 times
Invictus
Re: Union fails
Postby Invictus » Thu Feb 14, 2019 2:15 pm
Thanks, easyw-fc it worked!
Re: Union fails
Postby NormandC » Sat Feb 16, 2019 7:32 am
Unfortunately, the end shape is no longer parametric.
There's a much more efficient method: create only one Loft, and use Part Mirror to mirror it on two planes.
It's not the difference between the solids, the operation fails and produces only some of the faces. The problem is that the OCC kernel struggles to handle tangency between solids in Boolean operations. The lofts all end up with the same circular section at the top, causing tangency. The trick is to remove the tangency condition, which is easy here: make a single loft, and cut it along the XZ and YZ planes to keep only a 1/4 of it.
Boolean operations sometimes have trouble with solids that have co-planar faces, but they don't struggle as much as with tangency.
Then mirror it, fuse it with the loft; mirror the fusion, and fuse again.
Finally, set the Fusion001's Refine property to true to get rid of the residual edges on the top planar face.
This results in a fully parametric model.
Flue5_normandc1.FCStd
(119.88 KiB) Not downloaded yet
meme2704
Re: Union fails
Postby meme2704 » Sat Feb 16, 2019 8:45 am
My solution
couronne du roi des fous.PNG (42.13 KiB) Viewed 19 times
couronne du roi des fous.FCStd
(211.86 KiB) Not downloaded yet
meme2704
Re: Union fails
Postby meme2704 » Sat Feb 16, 2019 10:41 am
Even more crazy, model with bells with ball inside :lol:
couronne du roi des fous1.FCStd
(284.85 KiB) Not downloaded yet
couronne du roi des fous1.PNG (116.2 KiB) Viewed 1 time
cron
