0.18 maybe a bug in PartDesign?
user1234
Postby user1234 » Tue Feb 19, 2019 10:28 pm
Hello!
I maybe run in a bug in PartDesign.
I changed someting in the tree and FreeCAD refuses to refresh the tree. I want to mention that i also rearranged all topoligial issues before (chamfers, fillets, ....). It is a simple substractive primitive, that won't work, but all conditions should be correct.
Version
OS: Debian GNU/Linux buster/sid
Version: 0.18.15935 (Git)
Hash: afc44af3e9996419d457d02c9dde897f27b55341
Python version: 3.7.2+
Qt version: 5.11.3
Can somebody confirm this issue?
Sorry for bad english.
Greetings
user
bug.FCStd
(220.19 KiB) Downloaded 9 times
Re: 0.18 maybe a bug in PartDesign?
Postby chrisb » Wed Feb 20, 2019 12:40 am
Yes I can confirm. It seems to be a problem with recomputing. If I move the subtractive cylinder before PolarPattern024 and then move it back it all works.
Besides it is recommended to add chamfers and fillets last or at least late in the modeling process.
GeneFC
Postby GeneFC » Wed Feb 20, 2019 1:53 am
I had no problem recomputing, but Cylinder018 has an error symbol in the model tree. Looking at the Dependency Graph it seems that Cylinder018 is trying to subtract from nothing, i.e. no base feature. It is linked only to the coordinate system.
OS: Windows 7
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
Python version: 3.6.6
Qt version: 5.6.2
Gene
Postby chrisb » Wed Feb 20, 2019 8:11 am
Interesting find. I can repair it even faster than mentioned above, if I place it with "Move object after other object" directly behind PolarPattern024, where it was already before. This results directly in the following correct dep. graph:
Bildschirmfoto 2019-02-20 um 09.07.19.png (31.6 KiB) Viewed 206 times
It would be interesting to reproduce this.
NormandC
Postby NormandC » Sat Feb 23, 2019 7:31 pm
Off topic reply, just to say that FreeCAD looks great with a white background. I think I'll try it, and change the default part color to a light blue... Grey makes the whole thing a little dull. :)
