Start Points and order in face based toolpaths
sliptonic
Re: Start Points and order in face based toolpaths
Postby sliptonic » Tue Mar 19, 2019 8:48 pm
pauluzs wrote:
Tue Mar 19, 2019 10:39 am
Had some time again and updated the Startpoint picker from 2 posts above, for single engagement-point operations this works well.
Also it produces less screen clutter(on parts with many ops) as a screen full of green spheres like the holdingtag gui does.
sliptonic wrote:
Does it's behavior match what #3481 needs for 3d parts as well?
If I understand correctly, then yes. I'll be happy to take a closer look. Is your code in a git branch so it can be pulled and tested directly?
pauluzs
Postby pauluzs » Wed Mar 20, 2019 7:52 pm
This is great - I saw a PR being merged shortly which will sort all feature processing according to their position. It'll change behaviour quite a bit so an automatic selection makes a lot of sense.
Have to look into that, do you happen to have the PR#?
It doesn't have it's own branch, ATM i just paste the code from a few post back in the python console. If this is about the desired behavior in milling as well, i don't mind making translations, buttons and a GUI element. Al tough that will be after i figured out the algorithmic placement and have a decent working leadinout, for me being able to tool fast, simple and get a decent program has the first priority now.
mlampert
Postby mlampert » Wed Mar 20, 2019 8:08 pm
pauluzs
Postby pauluzs » Thu Mar 21, 2019 1:59 am
Thanks
New shorthand, cleanded up version, now also works on dressups when LockedToToolPath = False
view=Gui.activeDocument().activeView()
doc = Gui.ActiveDocument.Document.Name
LockedToToolPath = True
LoopSelection = True
FixedZ = False
ExtraHeight = 0
FreeCAD.Console.PrintMessage("\nSelect Startpoint or Operation\n")
def BaseOp(Object):
	if('Dressup' in (Object.Name) and hasattr( (Object.Base), 'Base')):
		if('Dressup' in ( Object.Base.Name) ):#Double Dressup
			if('Dressup' in ( Object.Base.Base.Name) ):#Triple Dressup
				return Object.Base.Base.Base.Name#Triple Dressup
			return Object.Base.Base.Name#Double Dress up
		else:
			return Object.Base.Name#Single Dressup
	else:
		return Object.Name#No Dressup
def SetStartPoint(Object, PickedPoints):
	FreeCAD.getDocument(doc).getObject(Object).UseStartPoint = True
	FreeCAD.getDocument(doc).getObject(Object).StartPoint = (PickedPoints[0], PickedPoints[1],((PickedPoints[2]+ExtraHeight)* (not FixedZ))+( ExtraHeight* FixedZ))
	App.activeDocument().recompute()
	FreeCAD.Console.PrintMessage(" \nSet Startpoint for: ")
	FreeCAD.Console.PrintMessage(Object)
	FreeCAD.Console.PrintMessage(("At:  X ",PickedPoints[0],"Y",PickedPoints[1],"Z",((PickedPoints[2]+ExtraHeight)* (not FixedZ))+( ExtraHeight* FixedZ)))
	FreeCAD.Console.PrintMessage(" \n ")
	if(LoopSelection == False):
		view.removeEventCallback("SoMouseButtonEvent",Callback)
def Done():
	FreeCAD.Console.PrintMessage("\nDone Setting startpoints\n")
class ViewObserver():
	def GetClicks(self, info):
		down = (info["State"] == "DOWN")
		PreSelection = Gui.Selection.getPreselection()
		Object = BaseOp(PreSelection.Object)
		PickedPoints = PreSelection.PickedPoints[0]
		if (down):
			if ( hasattr (FreeCAD.getDocument(doc).getObject(Object), 'UseStartPoint') ):
				if (LockedToToolPath == True):
			else:
				if (LockedToToolPath == False and (Gui.Selection.getSelection().__len__() > 0)):
					Object = BaseOp(Gui.Selection.getSelection().__getitem__(0))
					else:
						FreeCAD.Console.PrintMessage(" \n")
						FreeCAD.Console.PrintMessage(" Has no atribute: UseStartPoint\n")
				else:
Observer = ViewObserver()
Callback = view.addEventCallback("SoMouseButtonEvent",Observer.GetClicks)
FixedZ = False
ExtraHeight = 0
RatonLaveur
Postby RatonLaveur » Tue May 28, 2019 8:09 am
Hello Gents,
reviving this otherwise really interesting thread instead of making a new one.
I'm in the process of producing 2D parts with requirement of high accuracy, and therefore I need to control my start points with ease.
Specifically, I need to create Lead-In (no Lead-Out required but it does not matter). The current LeadIn dress-up is not working so well, or I'm very inept at using it, mostly I lament the seemingly impossible selection of whether the lead-in should be from inside or outside the tool-path.
Hence my current solution is to create a half circle indepent sketch (lead-in) and use Path FromShape to create the lead-in. The lead-in can be arbitrarily set inside or outside by mapping the half circle sketch reversed.
But I need the start point for the profile to coincide with the end of the lead-in. Now I could learn the position (or approximate position) of the vertex and manually input that. But I was hoping there'd be a better way.
Has anyone solved this yet?
Lead_in dressup not adequate.png (7.41 KiB) Viewed 124 times
Lead-in manually set by sketch.png (2.17 KiB) Viewed 124 times
Startpoint doesn't coincide between profile and end of leadin.png (1.96 KiB) Viewed 124 times
