Parallel Arcs Sketcher to Part Design Problem
Re: Parallel Arcs Sketcher to Part Design Problem
Postby chrisb » Sun Mar 03, 2019 9:13 am
One of the tangents is doubled. Remove either Constraint12 or 14.
Postby chrisb » Sun Mar 03, 2019 9:19 am
I was a bit wrong in my previous post, you have to remove Constraint12. The other tangency, Constraint14 is a line-line tangency, which does not imply coincidence.
Here is how the Sketch should look like:
Bildschirmfoto 2019-03-03 um 10.18.46.png (20.45 KiB) Viewed 195 times
TestArcs_cb.FCStd
(4.87 KiB) Downloaded 6 times
Gray Area
Postby Gray Area » Sun Mar 03, 2019 9:53 am
kisolre wrote:
Sun Mar 03, 2019 9:05 am
As ChrisB already mentioned in the first post - your sketch is hidden:
Toggling visibility by either selecting it from the tree and pressing "space" or LMB over it/Toggle visibility will show it:
Notice the black color of the name when visible and gray when hidden.
Also your sketch is overconstrained:
Since centers of are not constrained "coincident" they only appear to be on top of each other but do not depend from each other. Here is one of the proper constraining variations:
Thank you for your reply.
After several more attempts, I am now able to see the part in Part Design, as per your SketchVisible.PNG attachment. Thank you.
However, I am not seeing the Solver message as per your Overconstrained.PNG attachment.
Attached is a copy of what I am seeing. It appears that I may have no way of knowing where I might be over constrained with my version of FreeCAD.
Solver messages.PNG (14.08 KiB) Viewed 192 times
kisolre
Postby kisolre » Sun Mar 03, 2019 10:08 am
The message was from the original file that you posted here. You probably already fixed it of your local file.
Postby chrisb » Sun Mar 03, 2019 10:11 am
The solver messages showing redundant constraints are not available before version 0.18.
Gray Area
Postby Gray Area » Sun Mar 03, 2019 10:14 am
Thank you.
Yes, I did.
Gray Area
Postby Gray Area » Sun Mar 03, 2019 10:15 am
Thanks.
After some sleep, I'm going to look into downloading version 0.18.
Thanks again.
NormandC
Postby NormandC » Sun Mar 03, 2019 4:10 pm
Hello Gray, welcome.
Gray Area wrote:
Sun Mar 03, 2019 6:21 am
Version: 0.17.13528 (Git)
That version is outdated, the latest bug fix release is 0.17.13541 published last August. On the other hand, it's not worth downloading if you're going to download a 0.18_pre version (highly recommended, download link here); we are nearing 0.18 release, and more or less in polishing mode at this time. The current 0.18_pre is already pretty stable, and not far from a "release candidate" status without the name.
Gray Area
Postby Gray Area » Sun Mar 03, 2019 5:10 pm
Thank you.
I'm going to download it later today.
Gray Area
Postby Gray Area » Sun Mar 03, 2019 9:51 pm
Thank you.
I downloaded and installed the 0.18 release. And, I got a big surprise!
I opened a previous, much more complex, version of my test sketch with no problems whatsoever! Now, I have no doubt that the previous sketch is over constrained in multiple places, but it does not appear to matter in the 0.18 version.
Views of the previous sketch and part are attached.
Now, on to the next segment of the FreeCAD Learning Curve!
Thanks again to everyone for the help.
Gray Area
Support - Gas Tank.PNG (10.47 KiB) Viewed 158 times
Support - Gas Tank Sketch.PNG (59.97 KiB) Viewed 158 times
