conda-packages for osx
looo
Re: conda-packages for osx
Postby looo » Fri May 31, 2019 9:29 am
vectronic wrote:
Fri May 31, 2019 9:24 am
Also, did you build this using conda and then package as a macOS app? If so do you have any instructions to take the binary produced from the conda build and produce the app/dmg?
Everything is done with this script:
https://github.com/FreeCAD/FreeCAD-AppI ... osx_dev.sh
Postby chrisb » Fri May 31, 2019 2:32 pm
looo wrote:
Fri May 31, 2019 8:17 am
I updated osx 0.19 bundle to use qt5.9 The generated bundle should include FreeCAD 0.19.16881.
Please report back. Maybe you can also try to close the WebGui widget. This results in a crash on linux.
Thank you very much! I'm downloading right now, expectations are high.
Postby chrisb » Fri May 31, 2019 2:33 pm
vectronic's error looks similar to the one with the space path, so I hope there is only an issue with the calling script.
Postby chrisb » Fri May 31, 2019 3:28 pm
It doesn't run here either. If I call the executable directly I get
Fatal Python error: initfsencoding: unable to load the file system codec
ModuleNotFoundError: No module named 'encodings'
Current thread 0x00007fffa9155340 (most recent call first):
Abort trap: 6
looo
Postby looo » Fri May 31, 2019 3:54 pm
Thanks for testing. I have to try conda-packages directly (next Monday). Or if anyone else on osx is able to invest some time and learn the conda basics. This would help a lot.
looo
Postby looo » Mon Jun 03, 2019 5:59 am
can you post the output of:
echo ${VIRTUAL_ENV}
looo
Postby looo » Mon Jun 03, 2019 3:43 pm
Starting FreeCAD from a conda-environment works but first impression is worse than qt5.6 builds.
- no mouse wheel
- hangs at simple part creation
I can reproduce the crash of the bundle.
Postby chrisb » Mon Jun 03, 2019 11:02 pm
- no mouse wheel
sad to hear, my expectations were high.
good to hear.
Here comes an answer to the question from above: VIRTUAL_ENV is empty.
echo ${VIRTUAL_ENV}
I augmented the starting batch file to look like this:
#!/usr/bin/env bash
HERE=$(dirname "$(dirname "$0")")
export PREFIX=$HERE/Resources
export LD_LIBRARY_PATH=$PREFIX/lib
export PYTHONHOME=$PREFIX
export QT_QPA_PLATFORM_PLUGIN_PATH=$PREFIX/plugins
export QT_XKB_CONFIG_ROOT=$PREFIX/lib
export FONTCONFIG_FILE=/etc/fonts/fonts.conf
export FONTCONFIG_PATH=/etc/fonts
echo PREFIX:                      $PREFIX
echo LD_LIBRARY_PATH:             $LD_LIBRARY_PATH
echo PYTHONHOME:                  $PYTHONHOME
echo QT_QPA_PLATFORM_PLUGIN_PATH: $QT_QPA_PLATFORM_PLUGIN_PATH
echo QT_XKB_CONFIG_ROOT:          $QT_XKB_CONFIG_ROOT
echo FONTCONFIG_FILE:             $FONTCONFIG_FILE
echo FONTCONFIG_PATH:             $FONTCONFIG_PATH
echo {VIRTUAL_ENV}:               ${VIRTUAL_ENV}
"$PREFIX/bin/FreeCAD" $@
calling it I get the output
Desktop/FreeCAD16881.app/Contents/MacOS/FreeCAD
PREFIX: Desktop/FreeCAD16881.app/Contents/Resources
LD_LIBRARY_PATH: Desktop/FreeCAD16881.app/Contents/Resources/lib
PYTHONHOME: Desktop/FreeCAD16881.app/Contents/Resources
QT_QPA_PLATFORM_PLUGIN_PATH: Desktop/FreeCAD16881.app/Contents/Resources/plugins
QT_XKB_CONFIG_ROOT: Desktop/FreeCAD16881.app/Contents/Resources/lib
FONTCONFIG_FILE: /etc/fonts/fonts.conf
FONTCONFIG_PATH: /etc/fonts
{VIRTUAL_ENV}:
FreeCAD 0.19, Libs: 0.19R16881 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Sheet Metal workbench loaded
Desktop/FreeCAD16881.app/Contents/MacOS/FreeCAD: line 20: 32760 Abort trap: 6           "$PREFIX/bin/FreeCAD" $@
It shows the splash screen for a couple of seconds and crashes.
looo
Postby looo » Tue Jun 04, 2019 5:00 am
Yes I expected also to see some improvements.
regarding the crash of the bundle:
Seems to be related to qwebengine. In the log-file there is a message printed:
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Qt WebEngine seems to be initialized from a plugin. Please set Qt::AA_ShareOpenGLContexts using QCoreApplication::setAttribute before constructing QGuiApplication.
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Could not find QtWebEngineProcess
looo
Postby looo » Tue Jun 04, 2019 6:26 am
Removing the start/web module for now. Webkit is not yet available for conda-forge qt5.9:
https://github.com/conda-forge/qt-feedstock/issues/107
