2D improvement
Alexandr Parkhomenko
2D improvement
Postby Alexandr Parkhomenko » Sun Mar 03, 2019 7:17 pm
I found some incorrect behavior in opencascade. It is skipping items:
1 image - Example sketch model. Create minimum any 3 wires (lines, circles and other) with shared point.
2 image - Path module generate this.
3 image - a little magic and you can do so
Example sketch model. Create minimum any 3 wires with shared point.
Screenshot from 2019-03-02 19-54-54.png (158.57 KiB) Viewed 537 times
Now freecad calculate this.
Screenshot from 2019-03-02 19-55-05.png (113.29 KiB) Viewed 537 times
This is not released in freecad
Screenshot from 2019-03-02 19-59-11.png (135.34 KiB) Viewed 537 times
Re: 2D improvement
Postby Kunda1 » Sun Mar 03, 2019 7:30 pm
can you use a more up to date version of FreeCAD and OCC and test this issue?
also please share your Help > About FreeCAD > Copy to clipboard when you ask for help. It saves folks time to troubleshoot the issue for you.
Re: 2D improvement
Postby Alexandr Parkhomenko » Sun Mar 03, 2019 8:18 pm
OS: Arch Linux
Version: 0.19.10
Python version: 3.7.2
Qt version: 5.12.1
pacman -Ss opencascade
community/opencascade 7.3.0-4 [installed]
Open CASCADE Technology, 3D modeling & numerical simulation
latest from:
opencascade.com/sites/default/files/private/occt/OCC_7.3.0_release/opencascade-7.3.0.tgz
Re: 2D improvement
Postby Kunda1 » Sun Mar 03, 2019 8:45 pm
Version: 0.19.10
0.19 hasn't been released yet. Did you hack this yourself?
Also can you share an example file to reproduce this issue?
Re: 2D improvement
Postby Alexandr Parkhomenko » Sun Mar 03, 2019 9:26 pm
oops
here pkgver=0.17 --https://aur.archlinux.org/cgit/aur.git/ ... reecad-git
on screenshots 0.17
Re: 2D improvement
Postby Alexandr Parkhomenko » Sun Mar 03, 2019 9:30 pm
Standalone example of this trouble
// some headers
#include <STEPControl_Reader.hxx>
#include <Interface_Static.hxx>
#include <TopExp_Explorer.hxx>
#include <BRepLib.hxx>
#include <BRep_Builder.hxx>
#include <BRep_Tool.hxx>
#include <BRepAdaptor_Curve.hxx>
#include <BRepAdaptor_Surface.hxx>
#include <BRepBuilderAPI_FindPlane.hxx>
#include <BRepLib_FindSurface.hxx>
#include <BRepBuilderAPI_MakeEdge.hxx>
#include <BRepBuilderAPI_MakeWire.hxx>
#include <BRepBuilderAPI_MakeFace.hxx>
#include <BRepTools.hxx>
#include <BRepTools_WireExplorer.hxx>
#include <TopoDS.hxx>
#include <TopoDS_Compound.hxx>
#include <TopoDS_Solid.hxx>
#include <TopoDS_Vertex.hxx>
#include <TopExp.hxx>
#include <GeomAbs_JoinType.hxx>
#include <Geom_Circle.hxx>
#include <Geom_Ellipse.hxx>
#include <Geom_Line.hxx>
#include <Geom_Plane.hxx>
#include <Standard_Failure.hxx>
#include <gp_Circ.hxx>
#include <gp_GTrsf.hxx>
#include <Standard_Version.hxx>
#include <GCPnts_QuasiUniformDeflection.hxx>
#include <GCPnts_UniformAbscissa.hxx>
#include <BRepBndLib.hxx>
#include <BRepLib_MakeFace.hxx>
#include <Bnd_Box.hxx>
#include <BRepBuilderAPI_Copy.hxx>
#include <BRepBuilderAPI_MakeVertex.hxx>
#include <BRepExtrema_DistShapeShape.hxx>
#include <HLRBRep.hxx>
#include <HLRBRep_Algo.hxx>
#include <HLRBRep_HLRToShape.hxx>
#include <HLRAlgo_Projector.hxx>
#include <ShapeFix_ShapeTolerance.hxx>
#include <ShapeExtend_WireData.hxx>
#include <ShapeFix_Wire.hxx>
#include <ShapeAnalysis_FreeBounds.hxx>
#include <TopTools_HSequenceOfShape.hxx>
#include <TopoDS_Wire.hxx>
#include <BRepTools_ReShape.hxx>
#include <chrono>
#include <thread>
using namespace std;
int main(){
    // Loads file the STEP file
    TopoDS_Shape wires;
    STEPControl_Reader reader;
    IFSelect_ReturnStatus stat = reader.ReadFile("./shape.stp");
    bool failsonly = true;
    IFSelect_PrintCount fmode = IFSelect_ItemsByEntity;
    reader.PrintCheckLoad(failsonly,fmode);
    Standard_Real rp = Interface_Static::RVal("read.precision.val");
    Standard_Integer NbRoots = reader.NbRootsForTransfer();
    Standard_Integer NbTrans = reader.TransferRoots();
    reader.PrintCheckTransfer(failsonly,fmode);
	wires = reader.Shape();
	// here in sources make list...
    // version in freecad
	for (TopExp_Explorer it(wires, TopAbs_WIRE); it.More(); it.Next()) {
		BRepTools_WireExplorer xp(TopoDS::Wire(it.Current()));
		for (; xp.More(); xp.Next()) {
			xp.More();
			cout << "*" << endl;
    // correct version
    TopTools_IndexedMapOfShape localmap;
    TopExp::MapShapes(wires,TopAbs_EDGE,localmap);
    Standard_Integer numEdges = localmap.Extent();
    cout << "num EDGEs:" << numEdges << endl; //
    for (int count = 0; count < numEdges; count++ ){
    	TopoDS_Edge edge = TopoDS::Edge(localmap(count+1));
        BRepAdaptor_Curve curve(edge);
        switch (curve.GetType()) {
        case GeomAbs_Line: {
        	cout << "Line" << endl;
        	break;
        case GeomAbs_Circle:{
        	cout << "Circle" << endl;
        	break;
        default:{
        	cout << "Other" << endl;
	return 0;
Re: 2D improvement
Postby Alexandr Parkhomenko » Sun Mar 03, 2019 9:39 pm
Recompute (refresh) this project and put please screen here.
snowflake.FCStd
(5.77 KiB) Downloaded 11 times
Re: 2D improvement
Postby chrisb » Mon Mar 04, 2019 6:23 am
In another topic you talk about a patch, here you talk about a little magic, but I'm a bit confused, because I cannot find it.
In the standalone example you load a local step file, so I did not investigate this further. Could you please elaborate what you are doing/have done/will do?
The snowflake path changes here to the inner hexagon, if I change Direction from None to e.g. ZNegative.
Bildschirmfoto 2019-03-04 um 07.26.04.png (9.1 KiB) Viewed 460 times
Re: 2D improvement
Postby Alexandr Parkhomenko » Mon Mar 04, 2019 7:12 pm
Local step file in attachments. (Open snowflake.FCStd > Export Sketch as STEP)
        	gp_Pnt a, b;
            a = curve.Value(curve.FirstParameter());
            b = curve.Value(curve.LastParameter());
            cout << "     X" << a.X() << " Y" << a.Y() << "- X" << b.X() << " Y" << b.Y() << endl;
        	break;
OUTPUT:
num EDGEs:18
Line
     X19.05 Y22.4412- X14.605 Y30.2187
Line
     X17.78 Y20.32- X8.89 Y20.32
Line
     X19.05 Y18.1203- X14.605 Y10.4213
snowflake.step
(8.49 KiB) Downloaded 11 times
Re: 2D improvement
Postby Alexandr Parkhomenko » Mon Mar 04, 2019 7:30 pm
https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L3265
// see this function:
void Area::toPath(Toolpath &path, const std::list<TopoDS_Shape> &shapes,
const gp_Pnt *_pstart, gp_Pnt *pend, PARAM_ARGS(PARAM_FARG,AREA_PARAMS_PATH))
Minimum patch:
    for(const TopoDS_Shape &wire : wires) {
//#        BRepTools_WireExplorer xp(TopoDS::Wire(wire));
        TopExp::MapShapes(wire,TopAbs_EDGE,localmap);
        gp_Pnt a, b;
//#        for(;xp.More();xp.Next(),plast=p) {
//#            const auto &edge = xp.Current();
In attachments full version. This is the working sketch. Some people can use it to yourself with modifications.
Area.cpp
Try this file here: FreeCAD/src/Mod/Path/App/Area.cpp
(122.91 KiB) Downloaded 21 times
