Building Libs for Windows Debug Version with VS2017/Qt5.12
sgrogan
Re: Building Libs for Windows Debug Version with VS2017/Qt5.12
Postby sgrogan » Thu Apr 11, 2019 5:10 pm
UR_ wrote:
Thu Apr 11, 2019 12:08 pm
Are there any additional "tweaks" necessary?
I still don't understand why, but you can "brute force it" like here: https://forum.freecadweb.org/viewtopic. ... 10#p299534
Do you have a system installed boost? I think you have a Conda one?
sgrogan
Postby sgrogan » Thu Apr 11, 2019 5:20 pm
apeltauer wrote:
Wed Apr 10, 2019 5:01 am
Perfect!
@apeltauer, do you have time to try to build the python bindings of https://github.com/aewallin/opencamlib
I'm failing miserably. CMake won't let go of my conda python and when trying to build using conda libs I get bunches of unresolved external symbols.
apeltauer
Postby apeltauer » Thu Apr 11, 2019 5:25 pm
Maybe I find some time next week...
UR_
Postby UR_ » Thu Apr 11, 2019 5:27 pm
Yes, thats true. The Conda build works like expected.
I'm trying the build based on new libpack 12.1.2 with VS2017.
sgrogan
Postby sgrogan » Thu Apr 11, 2019 5:31 pm
In CMake watch what's linked. I've had problems with using the new libpack, some conda stuff is auto-detected and this destroys the config. If I set all the flags with a clean cmake cache, it works, if I run config again conda stuff creeps in.
tyszja
Postby tyszja » Sat May 04, 2019 11:45 am
Hi.
I'm not sure if this is related but my VS2019 needs Boost's exceptions lib and fails at linkage. Is there anything I can do about it? It seems that there is no boost_exceptions_vc....lib in the FreeCADLibs12.1.2 /lib/ folder or did I misconfigured something?
unresolved external symbol "void __cdecl boost::throw_exception(class std::exception const &)"
It's like ~200 link errors all over the place.
Site Admin
Postby wmayer » Sat May 04, 2019 1:02 pm
Are all your linking errors of the same type, i.e. that boost::throw_exception or are they different? Maybe you should open a new thread and post all your error messages there.
tyszja
Postby tyszja » Sat May 04, 2019 4:46 pm
I might do that although they all seem to be the same as pasted above so I thought I'll ask about it here first. BTW: I'm strugling to set up the build system on Windows for days now, while on Linux it was a matter of minutes... there must be something wrong with me but every time I want to do some serious work or get productive on Windows it fights me back. I guess I'm incompatible with it... or just prejudiced. ;) Thanks anyway.
zach
Postby zach » Sat Jul 13, 2019 8:49 pm
wmayer wrote:
Thu Apr 04, 2019 8:02 am
set PATH=PATH_TO_THE_LIBPACK\bin;%PATH%
start FreeCAD.exe --write-log %1 %2 %3
I stopped using Visual Studio some years ago and switched to QtCreator as IDE but IIRC you can also define a .bat file as program in Visual Studio.
I set up a batch file like this but for some reason it failed to find the correct file locations. When running the batch file I receive this error message:
I have FreeCAD built in this directory:
D:\Storage\Work\FreeCAD\Build2\bin
The batch file is in that directory as well.
Here is my batch file:
set PATH=D:\Storage\Work\FreeCAD\FreeCADLibs_12.1.2_x64_VC15\bin;%PATH%
GSoC FreeCAD Blog: zachgummow.github.io
Site Admin
Postby wmayer » Sat Jul 13, 2019 10:19 pm
Does your libpack have the file python36.zip as shown in the error message?
