Assembly 4 workbench
gjbgeo
Re: Assembly 4 workbench
Postby gjbgeo » Sat Nov 30, 2019 10:38 pm
Apologies if this has already been addressed.
I have just noticed if I move the folder containing an assembly, the links to object uses the full file path. For example, see the error in the image below.
Is is possible to use relative paths?
Thanks!
OS: Debian GNU/Linux 10 (buster) (XFCE/xfce)
Version: 0.19.18614 (Git) AppImage
Hash: efd55884ad7d40e77571a60c5bb906bbd8d1cbbd
Python version: 3.7.3
Qt version: 5.12.5
Zolko
Postby Zolko » Sat Nov 30, 2019 10:55 pm
yes, it was reported, it was an App::Link bug that saved path absolute and not relative, and it's fixed now. Please use the latest v0.19 built.
https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
aapo
Postby aapo » Sun Dec 01, 2019 4:10 pm
As a side note, you can fix your old model to use relative paths by simply loading it in its original directory structure into a newer version of FreeCAD, and then saving everything without making any changes. After that it will be possible to freely move/copy your model to some other directory path. At least, that worked for me in the same situation.
ppemawm
Postby ppemawm » Sun Dec 01, 2019 5:47 pm
Zolko wrote:
Sun Nov 24, 2019 10:25 pm
new version 0.7.4: I added an animate command. It allows to easily move parts in an Assembly4 assembly, by setting a variable in the Variables entity.
Thank you for those two enhancements. I especially appreciate the Variables tool which I will use from now on for sketches. Now, if we could just get the capability to add Expressions to the variable value?
So, I continued to explore top-down-design or in-context modelling with Assembly4 this week and tried something different by using shapebinders of the master sketch and external references rather than carbon copy. I was wondering if the animation performance would be improved. It was not. It seems all the time is in solving the master sketch for a change in the variable.
This assembly model of an articulating mechanism was built using drawings from a design by Brian Rupnow (2008), similar in complexity to my last project. A few comments regarding the process with a few screenshots:
This is a flyball governor typically used in a steam engine to signal an overspeed condition. As the pulley speed increases to the maximum, the air valve closes which provides a control signal.
The model was created in the same manner as my previous models starting with a top level master sketch. In this example, however, I used shapebinders with external references of the master sketch for each articulating body.
Assembly4 was only used for the pins in the articulating joints.
This is the master sketch which controls the articulation by the single variable "spring length" as defined in an Assembly4 Variables. It takes about 10-12 seconds for the sketch solver for each change in the variable value.
The variable can only be changed in small steps (<2 mm) to avoid breaking the sketch due to ambiguous constraints in the sketches for the Lower Ball Arm. I spent sometime trying to improve these but gave up after several iterations.
A carbon copy of the master sketch was used to capture the LCS's for all of the pin joints. The pins were merged from a generic pin Part file and edited for the appropriate length and diameter for each joint. Assembly4 was used to link each pin to its proper LCS, define the variable spring length, and animate the mechanism to verify proper motion.
The compression spring returns the flyballs to their resting position at zero speed. The spring's Helix parameters (height and pitch) are related to the Variables spring length as shown above. The pitch of the helix is simply its height/no. of coils.
Part>mirrors were used for the upper and lower control arms and the flyballs.
This GIF is from several images rather a screen recorder of the Assembly4 animator
since it was much too slow and it generated a too large of file to attach.
Assembly4 is proving to be an excellent vehicle for top-down-design or in-context modelling. It has become my starting workbench!
Questions for Zolko:
Is there any way to delete Assembly4 Variables?
Can expressions be added to the Variables value?
If anyone has interest in the FreeCAD file of this model please PM me for a Dropbox download link.
OS: Windows 10 (10.0)
Version: 0.19.18778 (Git)
Hash: f55cf3ef103532c9718c108bd856a4ef06ad49a5
Python version: 3.6.7
Qt version: 5.12.1
"It is a poor workman who blames his tools..." ;)
Zolko
Postby Zolko » Sun Dec 01, 2019 9:33 pm
You already can: you can set the value of one variable based on entries from other variables by an ExpressionEngine: right-click in the Properties window and toggle "Show All". You'll see a bunch of new parameters, AND in your variables value field appears on the right the "function" icon with which you can enter an expression. I only tried to divide by 2, I don't know how much it can do.
In this Show-All mode you can also delete variables
OK. I would have many questions, so may-be I'd rather take your offer:
Could-you please send me by PM a download link to your assembly ?
I'm curious to see how you built your model in the details.
ppemawm
Postby ppemawm » Mon Dec 02, 2019 12:49 am
Exactly what I needed. Thanks. Quite powerful.
Will do...I am interested in any feedback regarding the proper work flow as the software intends.
Zolko
Postby Zolko » Mon Dec 02, 2019 3:20 pm
thank-you, very interresting. I wouldn't have done it like that though: I'd rather use a first — static — master sketch at a particular position of the movement, and another — dynamic — master sketch representing the movement, where the movement's parameter is set to be one of the variables in the Variables object. And then, I attach all the LCS to the dynamic master sketch, and then I link the static parts to the dynamic LCS: thus, the parts are not recalculated at each step.
This of course doesn't apply to the spring which needs recalculation at each step, and I think that that is the longest calculation.
I'd be happy to get your feedback on my modifications to your assembly.
ppemawm
Postby ppemawm » Mon Dec 02, 2019 4:30 pm
I'd rather use a first — static — master sketch at a particular position of the movement, and another — dynamic — master sketch representing the movement, where the movement's parameter is set to be one of the variables in the Variables object....
thus, the parts are not recalculated at each step....
Quite clever. Now I have a whole new direction to explore.
Thank you for your time to investigate and improve my model.
I disabled the spring and it cuts the cycle time approximately in half.
Zolko
Postby Zolko » Mon Dec 02, 2019 5:42 pm
I made an update to the Assembly4 workbench (v0.7.5), which should improve the variable's handling and the animation speed. With that, when I disabled the spring calculation, the movement was in real-time. May-be you could give it a try ?
(what the animation now does is to update the assembly only, the Model, and not the entire document. Thus, parts that are in the same document but are linked into the assembly are not recalculated, only their positions. Except of course for the spring.)
ppemawm
Postby ppemawm » Mon Dec 02, 2019 7:40 pm
I made an update to the Assembly4 workbench (v0.7.5), which should improve the variable's handling and the animation speed.May-be you could give it a try ?
Yes, indeed. Much improved. Thanks, again.
That makes an excellent case to add all of the moving parts to the assembly Model as they are created so that clearances and collisions can be conveniently checked with the animator as the design progresses.
